Old 05-Jun-2006, 14:35   #1
yeti yeti is offline
yeti's Avatar
Should fit ok. You might need to play about with plate sizes to get the right stack height - usually 38mm, but it is do-able. Only other thing to note is shaft size, the S MAY have a 25mm shaft in which case you may or may not need a spacer and a new nut. Hope this helps.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:27.
