Old 28-Sep-2015, 16:52   #1
Andy Mack Andy Mack is offline
Bikes: DesmoDue Class A 620ss
Getting ready for 2016
Hello,
So i bought a bike off here (thanks skids) and wanting to get it all ready and sorted for next years racing.
There is a trackday on the 9th of oct at knockhill i was thinking of going too.
My main problem is the seat height is a bit low and close for me (i'm 6 foot 2). whats the best way of moving the seat up and back? Just getting brackets made up? or any other ideas?
Its an early SS frame and it currently has a 748/916 style seat unit.
Is there any other seat units that will fit the bike that might help give me a bit of room? And where is the best place to get replacement fairings?
Thanks for the advice.
Andy
Old 29-Sep-2015, 11:24   #2
steve41 steve41 is offline
Bikes: DD 620, 998 Matrix, 500 Pantah, Honda 350 K4, Drixton 500 Honda, Triumph 1050.
steve41's Avatar
Mood: Depends on how many crashes I have!!!!!
Andy,
I live near Dunfermline but wont be able to make it up to Knockhill, but both Brian Alexander and Jim Rodgers are 6 ft ish and run SS bikes, and local. Think Brian is going to try to pop up so worth speak to both of them. Speak to kev for contact details if you require, or drop me an email stevemason41@btinternet.com
I run a Monster and played with my seat with simple ally brackets.
Steve
Old 30-Sep-2015, 07:34   #3
From what I have seen in the past the use of 4 brackets with 50mm spaced holes to fit to the original mounts have been used to move the standard fitment seats back an up. then it is a matter of filling the gap underneath to support the weight so as not to break the mounting points.
As a non welder I used the blue modeling strofoam in the past as it is very light, easy to cut and shape. It is also strong enough to stand on
http://www.ebay.co.uk/itm/50mm-EXTRU...3D111672221476
Old 30-Sep-2015, 10:00   #4
Any idea where I'd get the brackets?
Old 30-Sep-2015, 18:23   #5
I usually buy lengths of 25mm (1 inch)wide alloy or steel about 2.5 to 3.0mm thick as it is ideal for fitting the slide on Dzus fasteners to and easy enough to cut with a hacksaw and put holes in with a cordless drill.
http://www.ebay.co.uk/itm/MILD-STEEL...item19d2c2083a
Old 30-Sep-2015, 18:59   #6
awesome! Thanks. Knew it would be a diy job!
Is the front fairing on the bike just a cut down 748/916 one?
And where would you get a replacement front fairing bracket? The one on it is a little damaged.
Old 30-Sep-2015, 19:22   #7
you could try brackets like these for re-positioning the seat
http://www.ebay.co.uk/itm/HAU-univer...3D310226105204
The fairing is in deed a cut down 748/996 top part
The fairing bracket I use is one of these
http://www.ebay.co.uk/itm/1718699290...%3AMEBIDX%3AIT
Old 30-Sep-2015, 19:46   #8
Awesome, thanks again!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:01.
