Old 14-Apr-2009, 04:54   #1
jimbers45 jimbers45 is offline
jimbers45's Avatar
Mood: Faster!!!
Ducati S4 2002 Showa Adjustable Forks
I bought a set of Showa adjustable forks off of the 'bay from a 2002 S4 (apparently) for my red 620.
Can anyone give me a clue as to the "factory" base settings for compression and rebound and how to get to them!.......and if you have any settings for a short fat slow F*$&er like me?
Old 14-Apr-2009, 07:58   #2
Try these
Click image for larger version Name:	S4 Forks.JPG Views:	366 Size:	89.6 KB ID:	10594
Old 14-Apr-2009, 12:18   #3
jimbers45's Avatar
Mood: Faster!!!
...the man is a veritable mine! Cheers Kev.....thats a great start! I'm assuming compression is 1, preload is 2, and rebound is 3?
Old 14-Apr-2009, 12:25   #4
Mac-Os Mac-Os is offline
Mood: bemused
Think rebound is 1 and compression is 3. If these are sprung like my old SS1000 showas you'll likely need max preload to stop them bottoming out.
Old 14-Apr-2009, 13:43   #5
as Mac says
1=Rebound
3=Compression
2 = preload (which is just rideheight)
My S4 Monster forks are fitted with single rate 0.85kg/mm springs
Spring
Length 365mm
Wire dia. 5mm
Spring OD 38mm
No. of Free turns 20
Works out a 0.85kg/mm
or 8.5n/mm
Preload spacer 222mm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:27.
