Old 02-Jan-2012, 20:12   #11
Drill sizes I use for tapping metric threads
M4 use 3.3mm Drill
M5 use 4.2mm Drill
M6 use 5.0mm Drill
M8 use 6.8mm Drill as Phil Said
M10 ISO Metric use 8.5mm Drill
M10 Metric Fine use 8.8mm Drill
Old 03-Jan-2012, 00:06   #12
Spjallen Spjallen is offline
Well I've not fit the bobbins yet but done my first ever tapping to fit the toe guard. Thanks for all the info on sizes of drill and taps. It worked out just great and was loads of fun to do!
Old 08-Apr-2012, 08:10   #13
Bobbins finally fitted to the alloy Swingarm. I just drilled and tapped the billet section - similar to skids. Case, finally after loads of measuring, closed.
Old 08-Apr-2012, 12:22   #14
My spanner man is going to do mine trackside at snetterton
Good to have people in your camp that actually KNOW what they are doing
Yes that's you Nick B
Old 08-Apr-2012, 20:06   #15
Why don't you do it yourself? You'll never learn unless you try?
Old 08-Apr-2012, 20:16   #16
Concentrate on the important things, like 18 layers of paint!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:23.
