Old 15-Aug-2004, 14:30   #1
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Originally posted by nelly
DC, it is the 955 kit you're thinking about..........unless you have a 916SP.
The SPS or R cams would go in OK. You may/may not need to machine the piston pokets, but you'd fuel it OK with an eprom change. I'm 95% sure the injectors are the same.
No need to swap them for the 855 motor I'm building, even with big valves and a gas flow
The 916 throttle bodies are 50mm whereas the 748 are 45mm downstream of the butterflys. I'm thinking of taking those out to 50mm or swapping for 916 items
Nelly,
I must make the trip up to see one day. I feel a winter engine mods list coming on!!!!
DC
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:41.
