Old 01-Dec-2004, 13:27   #1
stephen hall stephen hall is offline
stephen hall's Avatar
CANT GET THE HORN!!
I have a small problem with me horn .....it dont work ! only 3 volts coming down to it whip off horn put 12 volts into her... no problem... switch looks fine but only the 3volts when pressed....any ideas peeps as without me horn its gonner be a quite christmas
Old 01-Dec-2004, 15:30   #2
Is the three volts at the spade connectors or at the horn push?
If it's at the spades, then a broken wire sounds the culprit.
Try measuring from the positive spade but use a frame earth to see if it's the +tve feed that's broke. If not, then the earth could've broke. Either repair or run a new earth to the subframe.
Old 01-Dec-2004, 15:32   #3
YOU DONT NEED ONE ON A TRACKBIKE STEPHEN
Old 01-Dec-2004, 20:53   #4
Loz Loz is offline
Loz's Avatar
WHY NOT ? I DO ! ! !
Old 01-Dec-2004, 21:09   #5
kwikbitch's Avatar
You know...there are so many comments to make about this thread but I'm so tired
Old 01-Dec-2004, 21:31   #6
paulmort paulmort is offline
No sarcasm from KB..........whats happening to this lot, I ask meself?
mort
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:16.
