DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 21-Sep-2016, 12:30   #1
knappers knappers is offline
Wanted 600 carb flywheel rotor
Would anyone have, or know of anyone who has a 600 carb flywheel rotor to sell?
Thanks
Old 22-Sep-2016, 22:32   #2
Do you have a pic of the part you need
Old 27-Sep-2016, 18:49   #3
I haven't had chance to get to it to take a pic.
Its the magnetic rotor that spins inside the stator.
The link below shows it, its in the bottom left corner of the drawing. Thanks
http://www.stein-dinse.biz/eliste/el...6ebeb36g&lg=de
Old 27-Sep-2016, 20:16   #4
I'll have a check to see what I have, similar to the early 748 and 916 but narrower if I recall correctly but without measurements it is probably hard to tell one from the other
Old 27-Sep-2016, 21:29   #5
Yes you're right they are smaller. I'll look to see if I can find the dimensions again.
Thanks for your help
Old 27-Sep-2016, 23:16   #6
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
What year 583 is it? Marcus Dealey may have an early one in a box with the rest of a dismantled engine.
Old 28-Sep-2016, 10:33   #7
The engine is a 95 model. Thanks
Old 29-Sep-2016, 20:20   #8
Rotor size.
OD 76mm
ID 19mm
Depth 38mm
Approx.
Old 01-Oct-2016, 08:35   #9
I think it is the depth that is the dimension that varies between the models I will see what I have
Old 02-Oct-2016, 07:56   #10
That would be great, I'm really keen to get back on it while the weathers still good.
Thanks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:21.
