Old 14-Mar-2017, 17:46   #1
DSC Member Pimpf Pimpf is offline
Bikes: 1260s Multistrada
Pimpf's Avatar
Mood: Happy as Larry... Hope he's in a good mood.
Unhappy Heavy clutch
Has anyone modded their clutch to make it lighter to use, I find mine really heavy especially in traffic or when start/stopping. Ride for Life is coming up and last year it knacked my wrist/forearm, I was wondering if anyone had replaced the slave cylinder with the Oberon unit on an 899 and whether this had helped. I've also seen some chatter of air bleed into the system. I've not bled mine so I'm not sure if this is an issue or not. Any comments other than "more self pleasure with the left hand" would be greatfully received
Darren,
2018 Multistrada 1260S
Old 14-Mar-2017, 19:53   #2
PeteB PeteB is offline
PeteB's Avatar
Mood: ten, nine, eight oh bu**er lets go!
Fitted an Oberon to mine as standard too heavy for aging hands has obviously made the pull slightly easier but so far as I know nothing further can be done to make it lighter, unlike my MS1000 which has been running only 4 clutch springs for years with no problems!
Old 18-Mar-2017, 08:49   #3
Pimpf's Avatar
Thanks Pete, appreciate the response.
Darren,
Old 20-Mar-2017, 18:33   #4
The Hammer The Hammer is offline
Bikes: 1198, 748S, 900SS, SP1, Blade, 600RR, SV650N, RG125
The Hammer's Avatar
Mood: Hungry
My 1199 liked a regular purge of air fron the clutch lever bleed nipple every 6 months or so, regardless of fluid changes. Often no fluid would come out, only air, and this really helped with erratic clutch 'feel'.
Old 22-Mar-2017, 14:36   #5
Pimpf's Avatar
I'll give that a bash before changing the slave cylinder. Thanks
Darren,
Old 23-Mar-2017, 11:16   #6
The Hammer's Avatar
Mood: Hungry
Be mindful that changing to an oberon slave cylinder or such like may lighten the lever action but at the expense of increased lever travel at the bar
Old 29-Mar-2017, 18:09   #7
Pimpf's Avatar
Cheers, appreciate the advice.
Darren,
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:03.
