Old 13-Dec-2004, 00:41   #1
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
Re: Side panel fitting
The left hand side panel on my 748s is now really tight after coming back from its service, by tight i mean the holes for the 4 top dzus fasteners seem to have got further apart and the panel is really taught now a lot more so that before.
The frame 2 are fixed so I guess the front 2 may have moved? now it really takes a lot of force to get them in. The right side is easy to get on to any ideas?
Thanks in advance.
Old 13-Dec-2004, 00:51   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
so you mean the 'oles what line up on the nose cone?
all that comes to mind is the nose aint fitted properly... try taking it right off and re-fit.
Old 13-Dec-2004, 00:53   #3
Not sure but are all the Dzus fateners the same length, the top fairing is slightly thicker than the frame brackets so theymay use a 1mm longer Dzus.
Old 13-Dec-2004, 00:59   #4
moto748 moto748 is offline
The Dzus fasteners are all the same. I always find the LH fairing a bit more difficult to replace than the RHS, but I just put that down to the RH fairing being removed more often. You can always tweak the positions of the Dzus receptacles a bit.
Old 13-Dec-2004, 17:22   #5
You can adjust the backings, adjust by either bending them in or out (probably need a good strong pair of pliers) so that the dzus doesn't need as much force to lock.
Old 13-Dec-2004, 17:53   #6
Bikes: Xdaivel
Lee1980's Avatar
Thanks for all the tips, will try on the weekend when its light enough to see
Don't like the thought of the panel being under tension
Old 13-Dec-2004, 18:39   #7
yeti yeti is offline
yeti's Avatar
Think NBs hit the nail on the proverbial. Try loosening off - but not removing all the screws that hold the nose cone on, fit the side panel then re-tighten the nose cone. Worked for me in the past.
Old 13-Dec-2004, 18:40   #8
cashburning748r cashburning748r is offline
Mood: For Sale...
Hi lee
Had this myself, sadly.
There is a small clip that is designed to lock the two panels together, in my case the dealer neglected to make sure this clip was in the right place and instead proceed to reassemble. This caused the panel to bow slightly and exagerate the distance between the fastners which could be what you are describing...
Good luck with it, love the look v nice indeed
Old 13-Dec-2004, 19:03   #9
Originally posted by cashburning748r
Hi lee
beat me to it...I often forget the lug that sits behind the fairing panel which, if not placed correctly, makes it soooo tight to get on
Old 13-Dec-2004, 19:35   #10
Bikes: Xdaivel
Lee1980's Avatar
More replies shows how excellent this club is at helping out each other
I'm pretty sure the tab was located behind the nose cone.
Would they of taken off the nose cone for the 6000 miles service?
When I took the panels off the front head was still all dirty and can't really see how they could check the valves and stuff without cleaning it first? have some pics will post them up soon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:49.
