Old 19-Dec-2004, 15:24
748S 748S is offline
Help - 748S wont start
Can someone help please.....
Hadnt used my 748S for a couple mths so decided to go out for a blast... Started it ok and let it warm up on paddock stand for 10mins... revved it a bit like you do listening to the noise. Then switched it off.
Got kitted up , sat on bike.. hit the start button .... Nothing.... WTF.
Does not even try and turn over, Ive got lights so I assume battery is okay.
I can hear a short buzz when i switch on the ignition -- fuel pump ok then ??
all fuses seem ok - except one of 7.5A ones (fuses indicators ??) which has been blown for a while... however the bike has been running since
Dont look forward to trying to bump a cold ducati either
Cheer Daz
Old 19-Dec-2004, 15:29
keefer's Avatar
keefer keefer is offline
starter relay or power cable to starter motor
Old 19-Dec-2004, 15:35
Walenut Walenut is offline
Mood: Erratic
Has it got an alarm, if so check the inline fuse.
Old 19-Dec-2004, 15:50
Jasper's Avatar
Jasper Jasper is offline
Sidestand cut out?
Old 19-Dec-2004, 16:24
Could be the starter relay, take off the right hand panel, put a screwdriver across the two terminals of the starter relay, (ignition in the on position) if it fire up that is your problem, if it don`t, ask Nelly.
Chris.
Old 19-Dec-2004, 18:24
Fordie's Avatar
Fordie Fordie is offline
Regional Organiser - BHCN
Mood: Raring to Ride
On behalf of 748S ,My mate Darren, who is having dificulties in replying at the moment... Thanks . Looks like a case for Mr Haynes
Old 20-Dec-2004, 00:01
Sounds like the little white solenoid connector again..............
Pull the right hand panel off. The solenoid is on the lower right hand side of the battery as you look at it, it's a silver metal cylinder.
On the back of it is two power terminals and between them is a small white connector. Push this home fully and it'll probably start.
You can secure it properly with a small cable tie around it and the solenoid body to prevent future problems.
Old 24-Dec-2004, 09:19
Thanks for all the tips, all I want for X-Mas is a new
Starter Relay.......
Daz
Weeksey U2U mate
Old 24-Dec-2004, 12:12
Daz
Weeksey U2U mate
Last time I got one it was about £30.
Chris.
Old 24-Dec-2004, 12:52
rcgbob44's Avatar
rcgbob44 rcgbob44 is offline
When are we all going to wake up and by nice reliable Honda`s?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:22.
