Old 23-Dec-2004, 01:43   #1
kwikbitch's Avatar
999 mirrors? Will they fit an ss??
Well???
Go on......Enlighten me
I've seen a stunning pair of mirrors on Flea bay, with the indicators in them...Can I respray them?...(they are a nasty shade of red!)
MORE IMPORTANTLY....can I make them fit???
Old 23-Dec-2004, 09:50   #2
Stu Stu is offline
Mood: Cleaning the Weather OFF!
If they do fit, you'll have to let us know, and post some piccies!
Old 23-Dec-2004, 11:02   #3
FiscusFish's Avatar
Originally posted by Dseered
Mine are off at the moment, if you wanna borrow one and try you are welcome ?
DCR
Dog, could you measure the distance between the mounting holes for us. That'll be the quickest way to see if the'll fit. Standard mirrors (at least on the better looking SS's) are truly awful.
Darren
Old 23-Dec-2004, 11:39   #4
Stu Stu is offline
Can't be any worse than the SS's
...So they might aswell look good
Old 23-Dec-2004, 11:46   #5
chicken chicken is offline
chicken's Avatar
Darren
My SS mirrors are fantastic - I get a beautiful view of BOTH elbows
Old 24-Dec-2004, 08:58   #6
Hmm,interesting.I guess you could make them fit,but would it be worth it?
999 mirrors fit on the bike the same way as the 748/9** series.They have two pegs that you push into a clip and then a central shear bolt to stop them falling off.I guess these pegs could come out and be replaced with threaded rod or something?I'm not sure if they are threaded tho!
You might then be able to use the SS mounting bracket.The fixing centres may be differant,so be prepared for some drilling!You would then have to drill an extra hole for the indicator wires and run them down the fairing stay to pick up the SS wiring.The wires are a bit short,so may need extending.
I'm sure the mirrors would look great on an SS,but of little use.They would be a lot narrower than the origionals,so dont expect to see a lot out of them.On the 999 you have to get used to looking under your elbows.
Old 24-Dec-2004, 15:03   #7
Hi Lisa,
searched all over just for YOU !!!
I knew I'd seen some stylish ones somewhere.....
http://www.busters-accessories.co.uk....asp?prod=MMMI
or search the main page for 'mirror'
Good luck
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:41.
