Old 05-Jan-2005, 11:37
gman gman is offline
Modifications?
Has anyone modified the rear end of their MTS or does anyone know where I could get it done?
I would like to mount the rear light above the exhaust and into the seat cowling, something will have to be down with the indicators. I would also like to mount the number plate closer to the pipes so that you get a better view of the rear tyre - make sense?
G
Old 05-Jan-2005, 14:14
MARTIN H's Avatar
MARTIN H MARTIN H is offline
Have a look on MULTISTRADA.NET you will find all sorts of information and discussion for the multistrada.
Old 05-Jan-2005, 15:07
yes I have been on that site and they could not help but a good site for info
Old 05-Jan-2005, 22:00
chrisw's Avatar
chrisw chrisw is offline
Bikes: 999 Mono/1198S
Lights
Have you seen this site. They look quite trick with built in indicators.
http://www.kenscustomlights.com/749-999.htm
http://www.kenscustomlights.com/Ducati999/999.doc
Old 06-Jan-2005, 09:45
I'm liking those alot, however do you think
I could get them to fit in the seat cowling?
Old 06-Jan-2005, 22:41
chrisw's Avatar
LEDS
Don't know if they would fit.
How about these flexible arrays. Available in red and amber
Two shorties for the indicators and a central long one for the stop/tail (using the dual circuit converter) Cool
http://www.customdynamics.com/flex_led_array.htm
Old 06-Jan-2005, 23:23
Eamonn Eamonn is offline
Mood: Corners like a Lego man
Wow - with flexible led arrays you could make your bike just like Tron's !!!!!
Reminds me of a previous posting
Old 06-Jan-2005, 23:49
chrisw's Avatar
Multi-tron-da
I must have missed that thread. DISTURBING.
I wonder if they consider our obsession with Ducatis as strange?
Found this on ebay. They're for a CBR but they look trick and would possibly adapt.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Digressing, this may amuse you. (turn up the speakers)
http://www.philipcrammond.com/david/
[Edited on 7-1-2005 by chrisw]
Old 07-Jan-2005, 10:48
I assume you are thinking of mounting the rear light above the exhausts,and fix it or replace the bit of black plastic trim?
Not a lot of space there.The trim covers the rear portion of the subframe.I guess the led CBR light might just go in.(Did'nt iang fit one of these to a 999?)Also be carefull of routing the wires away from the hot can.
As no-one makes a plate relocator for the MS yet,you will probably have to toddle down to a local engineering shop to get one made.
Old 07-Jan-2005, 16:40
Yes pal thats exactly where I want to mount it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:49.
