Old 07-Aug-2018, 12:44   #1
GDBD59 GDBD59 is offline
Showa Fork torques
1000SS, - can someone oblige with the bolt torques of the top clamp, lower clamp & axle pinch-bolts please.?
I'm not sure how many other models share the same fork, 43mm Showa.
Old 10-Aug-2018, 15:54   #2
dunlop0_1's Avatar
I have never used a torque wrench for these just tightened them about the same as a spark plug, never had an issue.
Old 12-Aug-2018, 11:07   #3
I believe the Forks from the ST series are very similar, so as a guide here are those figures:
Tables never work so a * shows the main Nm figure
Category Component Torque (Nm) Torque (inch pounds) Torque (foot pounds) Torque Wrench
Frame Bottom Yoke Screw 20* 177 15 Medium M8 X 1.25 Shell Retinax HDX2 1-2-1 Sequence
Frame Top Yoke Bolt 23* 204 17 Medium M8 X 1.25 Shell Retinax HDX2
Frame Fork Bottom End Bolt 19* 168 14 Medium M8 X 1.25 Shell Retinax HDX2 1-2-1 Sequence
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:01.
