Old 07-Jan-2005, 11:28   #1
chicken chicken is offline
chicken's Avatar
Will a monster top yoke fit a carby-SS?
I'm thinking of cost-effective ways to make my Desmodue SS stand out a bit.
One of my thoughts is to "streetfighter" it with wide, flat bars. The fairing is coming off completely so clearance of the master cylinder is not a problem. I would definitely have to change the brake and clutch hoses, but don't know whether the electrical wires have enough give to reach.
Anybody done this? And anyone want to lend me a monster yoke for a year?
cheers, Chi
Old 08-Jan-2005, 11:26   #2
Certainly fit regarding bearings, headstock, nut etc. I'd be suprised if the wires weren't long enough. I think clearance would be the only issue (or not, in your case).
Old 08-Jan-2005, 11:28   #3
chicken's Avatar
merci!
Old 08-Jan-2005, 11:48   #4
monstermob 998's Avatar
recently saw a conversion kit for this mod on a website somewhere -------but cant find it now arrrrghhh included all the wiring and brake pipes etc with a new top yoke, bars and bar ends and steering damper!!!!!
Old 08-Jan-2005, 12:13   #5
FiscusFish's Avatar
I'd be suprised if the top yoke alone fitted without the bottom yoke and stem as well. I'd have thought the fork offset was different..
Darren
Old 08-Jan-2005, 14:44   #6
The ss & monster bottom yokes 'look' identical, but Darren's right, that's no guarantee the offset's the same. I'll check when I get home and let you know...
Old 08-Jan-2005, 17:30   #7
Darren's right, the monster offset is around 5mm farther forward than the ss. You would have to fit bottom and top yoke from a monster. Makes the steering even slower!
Old 08-Jan-2005, 17:58   #8
chicken's Avatar
hmmmm.....
so what should I do?
1) top & bottom yoke from a monster
2) get some brackets welded onto the existing yoke
3) get clip-on brackets for the fork and turn them to face each other to take a crossbar?
Old 08-Jan-2005, 19:13   #9
FiscusFish's Avatar
[Edited on 8-1-2005 by FiscusFish]
Old 09-Jan-2005, 00:40   #10
Or make your own
http://217.199.188.40/xmb/viewthread...=8660#pid70151
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:31.
