Old 10-Jan-2005, 18:31   #11
chris99 chris99 is offline
Mood: building the beast
Originally posted by Lily
mine is an 02 748r and it did the same.
for the price its worth getting a new battery and then get yourself an optimate if you are not gonna be on it for a while.
It was on an optimate thing though
Old 10-Jan-2005, 18:37   #12
So were ours and they still went caput within 2 years
Old 10-Jan-2005, 18:38   #13
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
Hi all,
Hope you all had a top festive period
When i got back i went to check on her and couldnt resist starting her up. I pulled the sheet off to be greeted by an iluminated neutral light when the ignition was off WTF . I
Thanks in advance
Chris it could be a back feed through the Reg rec/ alternator windings !simple to check! isolate the alternator by unpluging and then see if the neutral light goes out when ignition off!
Old 10-Jan-2005, 18:42   #14
Jasper Jasper is offline
Jasper's Avatar
Put a multi-meter across the terminals of the battery,reading the battery voltage.Then press the starter button.The voltage should only drop to about 9v.If it buggers off down to lower than that,i would change the battery.If it stays at battery voltage,then the solenoid is not fully closing OR there is a dodgy connection between battery,solenoid and starter.
Old 10-Jan-2005, 18:44   #15
The light seems to be behaving itself at the moment though
Old 10-Jan-2005, 18:44   #16
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Your getting 12v what when it's running?
When it's running it should charge over 12.5v as it needs to get over resistance in the batt.
But ti does sound like either your batt has died (most prob)
or the buzzing realy is faulty. Had same noise once on my 916 but bump started it in 3rd and it never happened again.
Old 10-Jan-2005, 18:47   #17
Bikes: 1098
madmav's Avatar
Mood: Chilled
Age996 i would have thought at least 13.6 v
Old 10-Jan-2005, 18:49   #18
Jasper's Avatar
13.6 to 14.2 is a correct charging voltage.
Old 10-Jan-2005, 19:55   #19
keefer keefer is offline
keefer's Avatar
sprag clutch
Old 10-Jan-2005, 19:59   #20
moto748 moto748 is offline
I wouldn't be in a hurry to sling a battery away before getting a meter on it and checking the voltage readings.
BTW the 13.6-14.2V referred to above is with the engine running at a decent lick, not at idle. The 12.5V is more like what you should see with the bikre idling.
Those white connectors to the solenoid are often the culprit. Orthe solenoid itself. If you clean up the connector, you can bridge across the two big HT terminals with a screwdriver or summat. If that starts the bike, then the solenoid needs replacing. They're cheaper than batteries.
All that's not to say that the battery isn't the most likely cause, though.
Or the rectifier....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:46.
