Old 14-Jan-2005, 17:21
Walenut Walenut is offline
Mood: Erratic
Clutch questions?
Hi All, Just a couple of questions, is the service limit on a 916 bip clutch plate 2.8mm? and if so what’s the thickness of a new plate? What sort of life expectancy should I expect (miles), and how much are a new set.
Just checked mine and all plates are below the minimum some down to the steel plate, nothing unusual there but the bike has only done 1500 miles and I’d expected to find a clutch as good as new.
Now there's no sign of abuse as the original tyres are on it still showing the pips, etc. But it was a 60 year old bloke who had it and to get onto the road he had to go up a long gravel drive?
The plates also show signs of getting hot.
[Edited on 14-1-2005 by S.P]
Old 14-Jan-2005, 17:30
Hmmmmm....sounds like lot's of nervous nelly clutch slipping going on trying to ride a bike with a tall first gear on gravel.
I reckon on about 12-15K out of a clutch pack in normal circumstances
Old 14-Jan-2005, 18:17
Are you sure that the plates which are down to the metal are not supposed to be plain in the first place? The pack should be alternate plain and friction plates. Its not unusual to see blue marks on the driven plates but they appear to go on working fine. Like Jools says, 12-15k would be about right and about £105 for a new set of plates (get the ally ones from the ST4 becasue they are a lot quieter).
Old 14-Jan-2005, 18:29
madmav's Avatar
madmav madmav is offline
Bikes: 1098
Mood: Chilled
Steve you should be able to tell by the state of the basket !
and are the plates badly hooked?
Old 14-Jan-2005, 19:49
Jon's Avatar
Jon Jon is offline
Mood: Tad more confident
SP the friction material on the plates, is not that thick to start with. You need to measure from the last pressure plate to the tip of the basket,
( 4.5 -5.00 mm) Individual thickness of plates is not too important, so long as you do have friction material on them. Some dukes SPS,R, etc. Have more thinner plates. How many plates do you have in the pack?
Old 14-Jan-2005, 19:50
Jon's Avatar
Jon Jon is offline
Old 14-Jan-2005, 19:51
Mood: Erratic
I’m pretty familiar with clutches so I now the difference between the plain and padded plates, the wear is not even and seems to be down to the steel only on one or two plates (both sides) although all plates are below the limit, the plain plates are a bit ruffed up as well. I’ve had a good look at the basket Keith and there is nominal wear on it, a few minor ridges nothing that would indicate the wear on the plates, odd really, inclined to agree with Jools, but I’m not that familiar with how bad or not a Ducati clutch basket will wear.
Old 14-Jan-2005, 20:34
Jon's Avatar
Jon Jon is offline
SP it depends on the use. I once had a stm clutch which slipped the moment it was fitted. It came with an alloy basket, which needed replacing after only 1000 miles. I now have a Bucci slipper fitted with carbon plates. To date I have done over 2000 miles and the wear rate and basket marking is very, very minor. The plain pressure plates should be smooth. What is the colour of the friction material on the friction plates. The reason I ask, is that if the plates have been swopped, ( unknown history). The previous owner could have taken out a more expensive clutch and made up a clutch out of used parts?
Old 14-Jan-2005, 21:01
Mood: Erratic
The material on the plates is black, the inner basket (the gear on the shaft) is alloy.,
Old 14-Jan-2005, 22:08
Its not stock 916 then.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:40.
