Old 17-Jan-2005, 00:08
Lee1980's Avatar
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Mood: Xdiavel..awesome!!
I think only the 998s got p34s as standard and i guess the r versions. my 2002 748s didn't get them although it says it does on the 2002 webpage
Old 17-Jan-2005, 00:34
rcgbob44's Avatar
I suggest you forget the calipers and fit Triumph conical hubs as fitted to the early Triumph Tridents, this will let you explore the finer handling caracturistics of your machine!
Old 17-Jan-2005, 07:53
moto748 moto748 is offline
Good idea. Then you can save more money by forgetting the slipper: you'll need all the engine braking you can get!
Old 17-Jan-2005, 07:58
Mood: Diet
I would normally recomend getting the suspension sorted, but it looks like you have already done that, so I would also recomend the slipper. I only have experience with the STM slipper, it seems to improve normal clutch operation as well as giving the slipper effect on downshifts.
Old 17-Jan-2005, 08:13
If I'd just bought a 748 and had £500 spare to spend, then unless I was 101% convinced it had already been done, I'd spend the money on getting a Ducati specialist to give it a good going over, checking the rockers, stripping the clutch, examining the loom for chafing, setting the TPS, etc etc etc.
Old 17-Jan-2005, 09:47
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Pro-Twins should be able to set you up with 4-pad calipers for around £200 including lines (which you will need as the fittings are different).
Pro-Twins - 01342 892 888 )Robert/Chris/Brett - these guys are seriously helpful).
If buying a slipper, make sure you get one with a hard wearing clutch basket - some of the cheaper ones are made from cheese. The ergal rating defines the hardness of the alloy - higher-better.
Also, I intend to change to alloy friction plates as soon as poss, as the standard steel plates hammer the alloy basket.
I believe the alloy plates for the ST4 are suitable.
BTW, a well set up slipper clutch is well worth the money.
Good luck.
Spinoli
Old 17-Jan-2005, 11:05
Harv748's Avatar
Harv748 Harv748 is offline
Hi Deej
As mentioned...P4's + a radial master cylinder...whhhhooooo there boy! Serious stopping power, and you'll still have some change from the £500.
If you can scrape some more pennies together....an 853 kit...ohh suits you sir!
  #18
Old 17-Jan-2005, 17:57
DC's Avatar
DC DC is offline
Mood: Double 9, Single 6.
I have gone to a radial master cylinder and P34 calipers on my 748. Wahoooooooooooooo!
What an improvement. They are truly awsome.
One of the best mods I have done to my bike bar the 853 conversion.
DC.
  #19
Old 17-Jan-2005, 21:42
deej's Avatar
deej deej is offline
weeksy i cant afford desmo due this year and i havent got the acu licence so thats a no go
moto748 the bikes all good on that front just ask harv !!!!!!!!
harv, i hadnt considered the 853 kit, sounds like a bloody good idea and just the extra reason to get the p34's at the same time. ps nice duke in your avatar
dc did you fit them yourself or pay for it to be done, what else was needed after you bought the kit and pads, did you find any unexpected hidden extra's ????
nelly how much for the p34's and radial cylinder please ??
[Edited on 17-1-2005 by deej]
  #20
Old 17-Jan-2005, 22:18
adam adam is offline
Mood: happy
deej, dont worry about 853, just pop in a 916-996, if its possible, but even with your 748 there is enough power already on tap. swap over brakes first. my mate had an R1, gave him a go on my then 748R (4 pad calipers) he nearly went over the bars, he was very impressed. Then do the slipper clutch
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:23.
