Old 16-Jan-2005, 22:03
Red-leader Red-leader is offline
Mood: wobbly !!!
Advise please, I need to tighten my headstock bearings.
Can I please have your advise, I have a click coming from my headstock when I brake. After 18,000 miles I guess its time to tweek the headstock bearing. I have not done it on this bike before. Can you please give me instructions and list of do's and dont's.
Thanks
Kev
Old 16-Jan-2005, 22:18
AK's Avatar
DSC Member AK AK is offline
Kev, Al has tootled off to have a look in his book for finer info.
He says if stuck, you are more than welcome to pop over one evening (Mon - Weds this week??) & he will assist if you like?
Cheers,
C
Old 16-Jan-2005, 23:31
Lee1980's Avatar
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Mood: Xdiavel..awesome!!
Which bike is it?, my 748s clicks like they are loose but it is the forks sliding back and forth inside so the dealer said colud be talking rubbish i guess
It does it when u push the bike back and forth on the front brake if its any help
Old 17-Jan-2005, 08:33
Mood: wobbly !!!
Its a 998 bip. This click is coming from the headstock I think. You can feel the click on the top yoke, could be wrong though. If its not to much trouble I will check it.
Thanks Kev.
AK
Have you got the manual ?
Old 17-Jan-2005, 09:35
AK's Avatar
Kev - Al has manual.
He was muttering about other possible things too - give him a call - the mobile will be on after about 1pm ish.
C
Old 18-Jan-2005, 13:50
RickyX's Avatar
RickyX RickyX is offline
Red,
You need a special tool to engage into the holes in the headstock nut.
I made one using a couple of 5mm drill shanks set into a block of ally. This fits inside a 32mm socket and that can then be torqued to the correct value (30Nm if I remember correctly).
You then need to back off the nut by 30degrees - use a protractor and a felt tip.
Best thing to do is to strip and re-grease the bearings and then set it up with no weight on the front wheel - a job I'm gonna be doing this weekend.
Old 18-Jan-2005, 13:58
keefer's Avatar
keefer keefer is offline
got a pic rick
Old 18-Jan-2005, 14:13
webbyc's Avatar
webbyc webbyc is offline
Mood: www.suzukisportingclub.com the only place to be
Kev - I'm sure there's someone on Visordown that may be able to help you!!!
Old 18-Jan-2005, 18:02
Mood: wobbly !!!
Yeh Right !
Old 19-Jan-2005, 14:08
RickyX's Avatar
Originally posted by keefer
got a pic rick
It's not pretty enough to photograph! It does the job and that all it does!
RX
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:37.
