Old 18-Jan-2005, 19:57   #1
Burty Burty is offline
Mood: broken ankled
900ss ie front drive sprocket fault
Hi there, new here.
Has anyone had a Ducati fitted front drive sprocket come off on their 900ss ie ?
Mine did, at 90mph.
Old 18-Jan-2005, 21:26   #2
moto748 moto748 is offline
I duuno about come right off, but some plonker I know had the sprocket trepan a hole in the grey plastic cover
So you need to keep an eye on the sprocket reytaining plate, and make sure it's not distressed. The grunty 2V engines are particularly prone to this (900SS, ST2).
Old 18-Jan-2005, 21:31   #3
There was, a while back, a new retaining plate introduced. The old ones wore the teeth away quite quickly. Look identical bar the new one is finished of in black rather than being uncoated metal.
Also make sure you loctite the screws when refitting the plate.
Old 18-Jan-2005, 21:42   #4
<Checks spare retaining plate in cupboard>
It's black!
Old 18-Jan-2005, 23:12   #5
Mood: broken ankled
Good point. I'd assumed it being fitted by a Ducati dealer, it should be up to the job. Obviously, it wasn't.
They had to put a new drive shaft in, as the splines had gone. But they didn't repair the damage to the swing arm or even replace the chain.
Old 19-Jan-2005, 00:29   #6
andys 900ss's Avatar
Now thats why the bolts were so hard to remove when I geared her down, and yes I did loctite the bolts back, heard this happened before on other bikes...
Andy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:55.
