Old 24-Jan-2005, 16:32
khu996's Avatar
khu996 khu996 is offline
A numpty chain question...
Excuse the lack of knowledge...
Im looking to replace the chain on my 749 as Im going up a couple of teeth on the rear and need a slightly longer one.
Will any good quality 525 chain do?
Do I need to worry about the different codes that go after the number? The manual says standard fitment is a DID 525 HV? What does the HV signify?
Old 24-Jan-2005, 16:40
were talking about the quality of the chain mate. I recon a nice gold DID 525 ERV (as good as it gets) the biz mate with a bigger rear sprocket!
Old 24-Jan-2005, 16:44
khu996's Avatar
So all 525 chains are essentially the same in respect of physical dimensions?
I know quality will differ, does it matter whether its an O-ring or X-ring chain?
Old 24-Jan-2005, 16:50
phil_h's Avatar
phil_h phil_h is offline
The side plate thickness does vary as you go from regular duty to heavt duty chain, but a duc is heavy duty specced anyway.
The only difference between an o-ring and an x-ring is shape
The x-ring is better because it gives a pair of sealing surfaces, and hence is better at keeping the original chain grease inside, and is slightly better at keeping cack out ... as long as you keep your chain clean(ish) !
All this adds up to less adjustment required
Old 24-Jan-2005, 16:57
If you wanted to be trick, go to a gold 520 erv as your buying a rear sprocket just a few more pence for a front aswell.
The 748 runs on a 520.......and so does most race bikes.
It was explained to me as, think about a match stick. try to break it. now cut it in half and try to break it again, itll be harder to achieve.
Search on this topic as weve been here before.
Old 24-Jan-2005, 17:08
chillo's Avatar
chillo chillo is offline
i can recommend Tsubaki
check b and c express:
bandcexpress.co.uk
Old 24-Jan-2005, 17:17
khu996's Avatar
Did a quick search, and read one of Shazaam's old posts about going from 525 to 520 on a 999, and he didn't recommend it due to the torque and weight of the bike. I know mine is a 749, but it weighs about the same?
Im not bothered about being too trick, 525 will probably do me fine, the extra 2 teeth should provide the change I want
Old 24-Jan-2005, 18:54
FiscusFish's Avatar
Do you definitely need a longer chain? I wouldn't have thought that going up two teeth at the rear would warrant it...?
Darren
Old 24-Jan-2005, 19:31
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
i have been warned about did chains by quite a few people
tsubaki is ment to be a much more reliable brand
Old 24-Jan-2005, 19:35
khu996's Avatar
Yeah, Alan at AJ Racing has confirmed what Shazaam said about needing a longer chain, an extra 2 links and a slight increase in the wheelbase should sort it!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:55.
