Old 31-Jan-2005, 19:01
crash crash is offline
Originally posted by FiscusFish
Carb Icing.
Felt like it wanted to cut out or a spark plug had gone bad? Fairly nippy out but not freezing and a bit dampish? Bike felt OK with throttle wide open?
Slkoline Pro FST or other such stuff.
Darren
Yep - that pretty much describes it. I know I have suffered carb-icing before, but never back-fires.
What is Silkolene Pro FST ? An octane booster ?
I always use super-unleaded anyway (Shell Optimax)
Thanks to all for your advice.
Dave.
Old 01-Feb-2005, 03:50
Mad Dog Bianchi's Avatar
Bikes: ST4S
Well, if you have eliminated the breather hose (do you use a tank bag that may slide forward and bend the hose at low speeds) and the carb icing problem, I would check the carb fittings. See if they are on nice and snug, with no air leaks around the mountings. I had similar problems and tightening up the mounts cleared them up.
93 750SS
Old 22-Feb-2005, 23:51
Carb Icing.
Darren
Darren - tried Silkolene Pro FST - works a treat
Thanks for the advice mate.
Dave
Old 23-Feb-2005, 00:04
Some good guys on here eh?
As an aside - I was surprised how much water was in my tank and and float bowls when last drained.
Happy riding - Frank
Old 23-Feb-2005, 00:19
Frank, how did you discover this, and how did you drain it?
I know how to do this for a diesel engine () but never imagined it to be a problem on a bike.
Dave.
Old 23-Feb-2005, 00:40
Two seperate occasions Dave....
Drained the Carbs the first winter I had the bike (there are drain screws on the float bowls and I ran hoses off them to collect the dregs).
and....last month I drained the tank to inspect for corrosion that I had seen previously.....I reckon there was about 50mls of water came out - surprised me.
Frank
Old 23-Feb-2005, 09:18
ali's Avatar
ali ali is offline
Mood: Damp
Originally posted by crash
Help.
Rode to the Ally Pally show today, and my 1993 900ss (carb model obviously) was backfiring all over the place (on the over-run, and also on a neutral throttle at low revs).
I have never suffered this problem before. Also, low speed running is very rough, and she will barely tick-over at idle. Every time I stop at lights and pull the clutch in - it stalls.
Anyone got any clues please?
Funnily enough these are the exact symptoms my 600ss was showing last week. Finally traced it to a knackered coil on the back cylinder. Pinched one off my 900 and all's well (until the 900 finds out!).
Think I'll get some FST in just in case!
Ali
  #18
Old 23-Feb-2005, 12:32
fil2's Avatar
fil2 fil2 is offline
Mood: is it still wet
Help.
Ali
exactly what i have a litre of at home now for just such an occasion.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:49.
