Old 28-Feb-2005, 17:24   #11
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Ahh, bling. Completely understand now.
Old 28-Feb-2005, 18:39   #12
RickyX RickyX is offline
RickyX's Avatar
Not 100% bling actually..........furriness equates to corrosion damage to protective cad plate which leads to corrosion of structural bolt which leads to (ultimately) failure and "Oh my gawd, no brakes" situation.......
See, always follow the mantra preached by the great guru:
"BLING IS GOOD, BLING IS SHINEY (But also can save you from death)"
Old 28-Feb-2005, 23:32   #13
Mr_S Mr_S is offline
But wouldn't you rather the cheap bolt corrode than the expensive carrier? I was under the impression that the cadmium is sacrificial.
This post of Shazaam's was linked to from the thread Jasper refers to above and suggests the same.
http://217.199.188.40/xmb/viewthread...=9368#pid76885
But, the mantra I like
Old 01-Mar-2005, 15:46   #14
RickyX's Avatar
Yeah, okay, you have a point there. However........if the disc carrier is correctly protected (anodised/painted etc), then that should prevent dissimilar metal contact and the carrier won't corrode.
I dunno, bikes are a bit wierd...in my day job, I would have a head fit if anybody even suggested putting stainless bolts into aluminium structure! Likewise, if anybody suggested putting carbon anywhere near ally I would also do my nut!!
Never mind...just keep chanting the mantra!!
Old 01-Mar-2005, 18:41   #15
adam adam is offline
Mood: happy
I know a guy who works at Harris Performance who said he can machine 1-2mm off the heads so they will be clear of the speedo.
Old 01-Mar-2005, 18:42   #16
Dibble
so need to pop down to B&Q for an orbital sander then ???
Old 01-Mar-2005, 18:51   #17
Mood: happy
Dibble, that did amuse me, cant stop chuckling. very good.
Old 01-Mar-2005, 20:13   #18
Felix Felix is offline
Going through myself, at the moment, Adam. From previous experience, I'd recommend using torx head as the hex heads are notorious for rounding off when you want to remove them.
I am going for a set of these:
Works about at about 4 quid each. Yes, mostly bling I must admit. If you have any interest we could combine the order.
[Edited on 1-3-2005 by Felix]
Old 01-Mar-2005, 21:24   #19
Mood: happy
Felix, are these the same size as the originals? mainly the head size.
Old 01-Mar-2005, 21:45   #20
Yes, at least they are on my bike. Head height is 5 mm, head diameter 13 mm, made by Poggipolini in Italy, official titanium supplier to Ducati Corse. Ordering mine tomorrow.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:34.
