Old 16-Jul-2003, 20:03
fletcherp fletcherp is offline
Mood: It's been better...
lap timer
anyone know how to get the lap timer to give a read out? It records fine, but everything I try to read the figures afterwards just swaps between the other functions or starts the bike - i.e. any combination of buttons 1 and 2 or the starter button. Anyone used it with success?
Old 17-Jul-2003, 07:42
dickieducati's Avatar
when you have finished your run/laps. turn the bike off. and then hold down the right hand button before you turn the ignition on. as soon as you have turned the ignition on release the button and it should be in readout mode. be careful not to keep the button pressed for more than 10 sec otherwise it will clear your times. then just use the left hand button to scroll through the laps. the top speed it gives you is 'true speed'. the speedo actually over reads by about 10%. had 157 true speed on mine so far on a private road. still more to go should see real 165 +.
Old 17-Jul-2003, 18:09
cheers!
I will try this soon!
Old 17-Jul-2003, 20:08
webbyc's Avatar
webbyc webbyc is offline
Mood: www.suzukisportingclub.com the only place to be
Let me know how you get on. Are you going to Rockingham?
Old 18-Jul-2003, 18:58
most definately - recovery form surgery on the 11th permitting!
Old 19-Jul-2003, 20:29
webbyc's Avatar
Surgery? Not from the shock of the imob not cutting out!!!!!!!!!!!
Old 21-Jul-2003, 10:43
no - I'm having go faster sugery!! (a lobotomy?!) - No its all quite boring - a hernia. As it is key hole and using a kelvar mesh as opposed to tons of stiches I am opptomistic that I'll be fit
Old 21-Jul-2003, 12:33
webbyc's Avatar
Don't they have a carbon version?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:59.
