Old 08-Mar-2005, 18:07
Harv748's Avatar
Harv748 Harv748 is offline
Fork protectors/bungs
You know what I mean, the jobbies than go in the spindle to provide some protection in case of a spill.
I know there are a couple of different makes out there...anyone used the JHP or tecmoto ones?
Any make better than another. Any a waste of time?
I believe someone makes a small diameter version, so the socket can go over them...any ideas who?
Ta
Old 08-Mar-2005, 18:34
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Hi Harv,
I've got the R&G ones intended for Ohlins forks. I use a thin peice of plastic stock to shim the fit my Showas, and wham them on with a rubber mallet.
It's a good idea to drill a hole through them, so that you can use a bar to get them out without mangling them. The kit also includes one for the r/h side rear spindle. About £27 ex-VAT if I remember correctly.
Not been tested (yet), but R&G bungs really saved my old TL from some major destruction, and they are very friendly and helpful to deal with.
Spinoli
Old 08-Mar-2005, 18:51
Jon's Avatar
Jon Jon is offline
Mood: Tad more confident
Harv have the JHP ones. can recomend that they work You don't even have to remove them to takeoff the front wheel. They are designed so that the socket passes straight over them
Old 08-Mar-2005, 19:02
Mr_S Mr_S is offline
Was thinking of the R&G ones myself, but wondered about the fitment. Spinoli, can you remove the wheels without removing the bungs?
Old 08-Mar-2005, 19:21
yeti's Avatar
yeti yeti is offline
They were not big enough for me, so I made some 2 inch diametre ones myself threaded onto a piece of 6 mm bar. The unscrew in seconds, but will hopefully protect the fork from all but the very worst spill.
Old 08-Mar-2005, 19:39
Jon's Avatar
Jon Jon is offline
That why it took so long to change wheels
Old 08-Mar-2005, 20:39
smilo006's Avatar
smilo006 smilo006 is offline
Mood: I like my bike
Just bought a set of R&G, fit a treat (Ohlins). There is German company www.b-g-racing.de something, German. They do a set of four for 70 Euros. They have 2 that also fit the back wheel too.
Old 09-Mar-2005, 00:19
Andy748's Avatar
Andy748 Andy748 is offline
Bikes: Ducati MS1200 & 916 track bike
Bought a set off a guy on ebayfor £15. They are the bolt and rod assembly described by Yeti and took minutes few to fit. I have not tried them yet, mind you the forks/brakes were one of the few things I did not damage when I dropped the bike at Silverstone last year.
Old 09-Mar-2005, 00:44
There was loads you didn't damage.
You only missed one session....
Old 09-Mar-2005, 09:35
Bikes: 998Bip
Mood: Carbonara
Hi Harv,
Re the R&G bungs - not sure if you can remove the wheel with them in place - I've never tried. However, I think the answer will be no.
I'll have a look tonight and report back.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:20.
