Old 10-Mar-2005, 15:19
748mart 748mart is offline
Originally posted by cmoss
Yes, I have the optional speed sensor, but would like this fitted professionally as it need rolling road to set mph. Not that many wires to connect but just don't have the time.
You could calibrate the MPH with a GPS receiver.
Old 10-Mar-2005, 15:48
Mark's Avatar
Mark Mark is offline
What is it with Essex & gps?? You must spend far to much time with Desmondo mate!
Old 10-Mar-2005, 18:48
cmoss cmoss is offline
Thanks contacted them, may be they can fit me in for a engine re-map as well. They will ring back tomorrow.
Old 10-Mar-2005, 21:29
yeti's Avatar
yeti yeti is offline
Don't be a poof!
Calibrate it on the paddock stand! Thats where I'll be calibrating mine when I get round to fitting it. Lovely bit o kit though!
Old 11-Mar-2005, 09:51
yeti's Avatar
Mossy, have you decided where to position your "speed" sensor yet? I had thought of using the front disc bolts as the "source" unfortunately they are stainless steel and as such will have no effect on a Hall effect switch. Think it may have to be the rear disc, but mounting the sensor is gonna be tricky.
Old 11-Mar-2005, 10:25
Felix Felix is offline
Mount it behind the front sprocket so that it triggers off the teeth. Works great and you don't have to deal with the wire going through suspension.
Old 14-Mar-2005, 20:41
yeti's Avatar
Will that really work Felix? Have to admit it would be a wonderfully elegant solution.
Hang on tho, it won't show the right speed when I'm sliding the rear wheel tho.......
  #18
Old 14-Mar-2005, 20:47
As long as you can program the dash for the right number of pulses per revolution then it will. I've done this a few times with Stack gauges and it worked a treat. The correct number of pulses, by the way, is the number of teeth of your rear sprocket. Obviously, you'll also need to enter tyre circumference.
To other error, beside the rear tyre spinning, is when you're cranked over on the edge of the tyre as the circumference is less when compared to the centre of the tyre. Not that that would be a problem for you, I presume.
  #19
Old 14-Mar-2005, 21:07
Rob B's Avatar
Rob B Rob B is offline
Mood: I'm so happyyyyyyyyyyyy
Yep, to all that, you can program the dash with a bit of string not a dyno. Ehh?
Well, lay a bit of string (or a tape measure) in your drive. Mark a point on your tyre and push it along, your only measuring the circumference. With that number, you can do the rest of the math to workout (and programe in) whatever detail the dash needs. Eg. how far you are travelling per tyre revolution and how many pulses per rev of the sensor (if you put it on the gearbox O/P) is a simple calc on the 15/41 (or whatever) ratio of the final drive.
Happy to talk you through it if you want to give me a call.
Rgds, Rob
  #20
Old 14-Mar-2005, 21:31
Hi All, contacted company at Garstang but they are not interested in doing the dash as they say it needs a bracket making, never mind looks like Super Glue and some cable ties are in order. I just wanted to drop it off and in a couple of days pick it up all down and dusted, as last year spent too long fiddling with add ons instead of riding the bloody thing. But looks like a few weeks in the shed to sort out
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:44.
