Old 18-Jul-2003, 20:28   #1
Dude Dude is offline
Dude's Avatar
Mood: Ducatiless, but got License back
Wont Start off button - but will bump off
2001 748S Alarm and Immobiliser removed.
Bike does not start off the button!! I turn the igition on, get the fuel pump whirr, but nothing when I press the start button. Also indicator no longer work
Thought it may be a fuse, but checked them all. Bike will bump off, but getting a bit sick of bump starting her all the time.
Anyone else had a similar experience or able to shed some light on it?
Thanks in advance,
Old 18-Jul-2003, 20:36   #2
DJ Tera DJ Tera is offline
can you hear a clicking sound when you press the button?
Old 18-Jul-2003, 20:53   #3
Nigel Booker's Avatar
Have you checked the starter relay connections had the leads disconnect themselves twice in 12 months.
Old 18-Jul-2003, 20:55   #4
Forgot to mention that my local ducati dealer didn't fix the problem an RAC mechanic that took part in the pro thunder series said its a common fault.
Old 18-Jul-2003, 22:07   #5
As Nigel discovered, a common problem with superbikes is that after running fine and then shut off, it won't start again, say after a refueling stop. Sometimes if you wait a few minutes it will restart normally.
The culprit is the two-wire plastic connector plug located behind the starter relay (the round gold component near the battery.) The connector often makes a poor connection from distortion or corrosion. Usually jiggling or unplugging and plugging the connector will get you going again.
Old 19-Jul-2003, 01:43   #6
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
And once you plug it back in, get a cable tie wrapped around it
Andy
Stuck outside Mulsanne ( could have been worse I suppose! ) for 20 minutes till I fathomed it out........
Old 19-Jul-2003, 06:41   #7
Did you remove the alarm/imobiliser yourself?
It could be you have missed a link out of the wiring loom.The alarm/imobiliser is just a series of contacts that interupt the supply to components such as the starter button and fuel pump.My guess is that there are some poor connections somewhere.
Old 19-Jul-2003, 10:21   #8
Dude's Avatar
Thanks for your comments.
I will check the connections around the relay area and clean them up.
DJ - there is no clicking like in a flat battery, just nothing at all.
It seems to be an intermittent fault that has come and gone - usally only a couple of minutes each time, but now has stayed for over a week. Does sound like a connection problem.
I will report back
Old 19-Jul-2003, 11:09   #9
Guido's Avatar
Mark,
Might be also worth checking the starter button housing itself. Does get water/crap in there and may not be connecting properly...a long shot after trying the other suggestions.
Gc
Old 19-Jul-2003, 22:41   #10
Mood: aving a laff
Dude
Nelly is a registered alarm man for Datatool so quiz him if no joy with other options but must agree that removing the cut out from the starter solenoid got mine going again last year.
You need to remove the cut out from the solenoid and remove the alarm loom connection then plug the original plug back into the solenoid.
Two minute tops including removing the fairing.
Best of luck dude
Yella
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:20.
