Old 21-Mar-2005, 20:51   #11
A few exhaust facts.
1) all 749, 999 std exhausts are the same.
2) the "race" can will fit onto the std or de-cat front pipe and run.
3) In my opinion, if your shelling out for the "race" system, which remains assymetrical, you might aswell spend a little more, and get a proper balanced system.
4) If you upgrade the exhaust, hell, even if you want your std bike to run correctly, id say have a PC 111 usb, and a bit of dyno time.
5) If you do the pc route, you dont need a new CPU, as the fuelling can be set with the PC!!
6) If you go the non Termi route, ie with another make, you dont get a cpu, so need the PC anyway!
Old 21-Mar-2005, 22:42   #12
UKRR UKRR is offline
Mood: Got the S - waiting for the Termi's
Unless - of course , you have a 749R.
Choices are - full 57mm termi or equivalent.....that's it !
Alternatively you 'do it yourself' with an assymetric system from another model...although I hear that Termi will be making an assymetric system specifically for the 749R this year.
I don't know what other options are available given that the 749R has a deep sump and a fabricated swinging arm ?
Old 21-Mar-2005, 22:45   #13
yup, ill give you that. I was refering to the cast swing arm models........
Old 21-Mar-2005, 22:48   #14
Andy
Sorry for coming across as an anorak there !
Just wondered if anyone knew of any viable alternatives for the 749R.
I'd like a balanced system but - hey call me cheap - but I don't want to shell out the best part of 2.5K and a termi or a Leo system
Old 21-Mar-2005, 22:51   #15
Also - agree with you about the CPU issue.
I had a 996S before my 749R and I couldn't get it to run properly using DP chips.
Put a PC on it and it ran really smoothly after being set up an the dyno.
My dealer suggests that a new CPU isn't really necessary.
Old 21-Mar-2005, 23:03   #16
pedro pedro is offline
pedro's Avatar
Mood: r
my 749r has the assymetric system
[Edited on 21-3-2005 by pedro]
Old 21-Mar-2005, 23:09   #17
bolds bolds is offline
Hey Pedro is your 749R running problem sorted now?
Old 21-Mar-2005, 23:12   #18
pedro's Avatar
Mood: r
no not yet,its having a new wire loom tomorrow,jhp is conifident this is the route of it,nought to do with termi etc,just a faulty loom.done by end of week.
Old 21-Mar-2005, 23:14   #19
I,ve got the assymetric ordered for my 749R.
Apart from the noise - was there any noticeable difference with the new system ?
Old 21-Mar-2005, 23:15   #20
pedro's Avatar
Mood: r
u have u2u
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:43.
