Alarms and Related Security
Old 23-Mar-2005, 23:11   #1
datatool 3
anyone know how I can remove the battery for charging without setting off the alarm??? Looked at instructions and it talks about charging on the bike - no good for me as I dont have power! Any ideas?
Old 23-Mar-2005, 23:37   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
not a lot of help i know but you have to put it in service mode.
im quite drunk right know so i aint going out to the garadge to look at alarm manual.
butb i'll check it tomorow and post
Old 24-Mar-2005, 00:14   #3
HW HW is offline
Disarm as if you're going to start the bike. Turn on the ignition and then press the arm button on the fob and hold it until it beeps at you. You can then turn the ignition off and disconnect the battery. You will hear a beep every 15 seconds or so for the first day (ish) even after you take the battery out.
To put back to normal after putting battery in, just treat it like normal disarming/starting.
Henry
Old 24-Mar-2005, 13:45   #4
stuart hill stuart hill is offline
stuart hill's Avatar
Yeah, service mode is the answer.
The user guide is on datatool's website:
http://www.datatool.co.uk/documents/...er%20Guide.pdf
Old 24-Mar-2005, 14:10   #5
cheers guys, but want to do it without the beeping, bike in the garage on an alley and dont really want to advertise the fact its there! Got a solution of using the monnie battery while on charge, so looks like I'll have to do that.
Old 24-Mar-2005, 16:12   #6
HW HW is offline
Sure - as far as I know the only thing you can do is replace the battery with another while you do this. The beeping does stop, after a while. I had my battery off for a few days recently and it was not beeping the following day.
Old 14-Apr-2005, 19:28   #7
ils ils is offline
I had the same problem - the beeping through putting it in service mode was bloody annoying, so now I just put an old battery in place which keeps the alarm happy (and quiet).
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:53.
