Old 25-Apr-2005, 21:54   #1
moto748 moto748 is offline
Woo hoo! I just bled my back brake!
Successfully!
Quite a while back I bought a Mityvac* vacuum brake bleeder. Largely because the back brakes on 748/996's, even when they are working, to their limited degree, don't stay solid for long. And partly because the bike's getting to the age where I really ought to be tackling some of the relatively straightforward routine maintenence jobs myself.
As the back brake had disappeared to absolutely nothing lately (all that happens is the pedal hits the fairing), I decided that the brake bleeder ought to stop gathering dust under the stairs.
I mean, I've watched Louigi do it plenty of times: how hard can it be?
Well the answer is, if you've got one of those things, it's no trouble at all!
Boldly ignoring the advice of the Haynes manual
This procedure will be easier with the aid of an assistant
I set to, and the job was done in no time. I extricated the caliper from the wheel, and hooked it over the near-side pillion footrest, which seemed at a convenient height to get the nipple as high as possible. Two or three pumps with the vacuum bleeder, then a couple of pumps "conventionally" at the pedal, and the pedal is now as solid as you like.
So I thoughly recommend this excellent bit of kit. Anything that makes the difference between it being a into-the-dealers job, and a DIY job (quick-relaese sprocket carriers are the same, in my opinion), soon pays for itself.
Might be a while before I'm brave enough to tackle the front brake and clutch, though...
* I bought mine direct from the States off ebay. And, maybe I was just lucky, but I didn't get hit for any import duties or such-like either. Cost me about £55 all in, IIRC. I believe they're the best part of 100 notes retail in the UK.
[Edited on 25-4-2005 by moto748]
Old 25-Apr-2005, 22:22   #2
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
yep, that sounds about right. When I bleed my rear brake I always undo the twp bolts and just turn it around on the disc so the bleed niple is at its highest point. Then bleed away. 3 min and loverly pedal action.
DC.
Old 26-Apr-2005, 17:05   #3
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
Mityvac from Hein Gericke in Stockwell, £35. However, usefully the instructions were in German but it is not difficult to use.
Great little tool though.
Old 26-Apr-2005, 17:07   #4
Dibble
will one get the jam out of donuts without leaving a mark ???
would be great to wander round sainsburys with one of those ....
Old 26-Apr-2005, 17:21   #5
Got one from Hein Gericke ages ago without instructions, so never used it, don't even know how to connect the thing up, any ideas/help appreciated
[Edited on 26-4-2005 by JPM]
Old 26-Apr-2005, 17:24   #6
tricky tricky is offline
Mood: Need spares
Old 26-Apr-2005, 18:58   #7
m1keyp m1keyp is offline
http://www.mityvac.com/
Just ask and you will receive
Old 27-Apr-2005, 14:19   #8
Well in fact I did the front brake last night! Solid as a rock now.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:41.
