Old 29-Apr-2005, 09:54
ian johnson ian johnson is offline
Mood: RIDING FOR THE DARK SIDE
999 ecu light
this morning the light on the dash came on and stayed on
switched ignition off/on still on .seems to be running ok to work only 7 miles.
question is why?
any harm done?
how to rectify?
Old 29-Apr-2005, 10:43
tricky tricky is offline
Mood: Need spares
If its staying on best bet is to get to a dealer and have plugged in to see whats wrong.
I've also got a feeling you can hold a button combination down an get a diagnostic error code on the display. I've got a doc with the error codes in but thats at home and Im in the office at the moment.
Old 29-Apr-2005, 10:48
Could be anything or nothing, was/is it running OK?
I got the ECU light after picking it up from JHP, didn't worry about it, next time it went back in they checked and it was the clutch switch??? apparently there's a switch to tell the ECU when you disengage the drive train, as I had switched to a brembo clutch master cylinder I got the error, simple!
Old 29-Apr-2005, 10:51
all seems to be running ok but i took it very steady just in case.
Old 29-Apr-2005, 11:40
Gizmo Gizmo is offline
Mood: is it the weekend yet??
The clutch switch thing is quite common it occurs when you are first pulling away or slowing down to lights etc and light comes on briefly, I had it on mine and was told to adjust the micro switch, I left it till it was serviced earlier this week and hey presto, no light coming on. I'd seen a few posts on here about it where the dealers had told them "they all do that" . According to Ducati Leeds its a well documented fault which Ducati UK can advise dealers on fixing. makes you wonder how good a dealer is if they can't even phone DUK and ask about it.
Old 29-Apr-2005, 13:20
just started bike to check and lo and behold no freakin light
annoying or what.
Old 29-Apr-2005, 15:32
annoying or what.
What?? you liked it so much you want it to come on?
It'll wait till you're 100 miles from home on a cold wet night before it does it again
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:11.
