Old 02-May-2005, 18:13
bgruhn76 bgruhn76 is offline
Evolution Moto Performance Module
Are these worth looking into? Sounds to easy.
http://cgi.ebay.com/ebaymotors/ws/eB...tego ry=35597
Old 02-May-2005, 18:15
Or this one...??
http://cgi.ebay.com/ebaymotors/ws/eB...tego ry=33597
Old 02-May-2005, 19:07
No, these modules will change your timing.
If you buy one you're probably too retarded anyway.
Old 02-May-2005, 19:34
I know nothing about Ducati's this is my first.
Save the smart a$$ comments for someone else please.
Isn't this why these forums exist? For info?
Old 02-May-2005, 19:59
Sorry, humour is sometimes hard to convey in a forum.
Ducati Engine Management System
Ducati’s engine management is provided by an open-loop fuel injection system that uses a computer to control the opening duration of its injectors based upon voltage levels presented to it from several sensors. The longer the injector is opened, the more fuel is supplied to the engine.
The computer contains a Eprom chip that stores a look-up table of injector durations for 16 throttle positions and 16 engine speeds. This chip can be removed from some computers and replaced with one re-programmed with different durations (fuel map) needed for fuel mixture changes necessitated by engine modifications. The fuel map supplied by Ducati is programmed to provide good fuel economy and to meet exhaust emission standards, so does not really provide optimum performance.
The chip also contains a look-up table of degrees of ignition advance (spark map) for the same 16 throttle positions and 16 engine speeds that are used for the fuel map.
The computer determines throttle position from the voltage level sent from the throttle position sensor (TPS) and determines engine speed from pulses sent from a pick-up coil on the engine that indicates crankshaft RPM.
Unlike a closed-loop system that also samples its exhaust gases to make corrections to fueling, the Ducati system only makes corrections (trim factors) to the base map based upon engine coolant temperature, ambient air pressure (altitude) and temperature.
The coolant temperature sensor (thermocouple) monitors the engine coolant temperature so the computer can supply additional fuel while the engine is warming-up and retard ignition timing if the engine gets too hot.
Engines need more fuel when for a cold start as there is no heat in the ports and chambers to keep the fuel atomized as vapor, so it condenses. Fuel as a liquid burns very badly in the combustion chamber, so throwing more at it ensures enough stays as vapor for some sort of combustion. Injected engines get a very nice fuel spray from the injectors and this is why injected engines behave well when cold.
The atmospheric pressure sensor monitors the air pressure so that the computer can supply additional fuel when you ride at lower elevations where the air is more dense. Conversely, if you ride in the mountains where the air is thinner, the voltage output of the sensor drops, which tells the computer to make a pre-programmed reduction to the fuel map injector durations.
The atmospheric temperature sensor voltage level tells the computer how much to modify the fuel map injector durations for a given air temperature. When you take a ride on a hot day, the air is thinner and consequently will cause an engine that has its air/fuel mixture set correctly for a nominal 68°F day, to run too rich. The sensor's resistance increases with air temperature.
Intake Air Temperature Sensor
When you take a ride on a hot day, the air is thinner and consequently will cause an engine that has its air/fuel mixture set correctly for a normal 68°F day, to run rich.
To avoid this mixture variation, Ducati fuel injection systems have been provided with air temperature sensors that tells the ECU how much fuel to deliver for a given air temperature. The atmospheric temperature sensor voltage level tells the computer how much to modify the fuel map.
For a given ECU fuel map, there is a range of enviromental trims. So, when the air is colder than what the map says is "ambient" - 70°F or so - the ECU adds fuel. If it's hotter than 70°, it reduces fuel. The sensor's resistance increases with air temperature, 30 K-ohms at -20°C, rising to 370 K-ohms at 80°C.
When this sensor fails to an open circuit (infinite resistance), the resistance goes outside this range. So, to avoid letting the computer think that the day is very hot and producing an overly-lean fuel mixture at normal operating temperatures that could damage an engine, the computer defaults to the preset ambient setting.
So, with a properly set-up engine with a given maximum capacity for volumetric air flow, tell me, how will modifing the resistance of the air temperature circuit with one of these devices result in a more favorable air/fuel ratio and more power? In my opinion, it can't and won't.
Old 02-May-2005, 20:05
Holy crap...ok..thanks.
I figured it was a crappy scam.
Thanks for confirming.
I am having the bike looked over by Casoli Motors here in the states...I will post outcome for opinions.
Thanks.
So EPROM upgrade for $180 US is the way to go?
How can I tell if it already has it?
Old 03-May-2005, 00:07
Mr_S Mr_S is offline
First time I've seen any comments from Shazaam! described as smart ass....
Old 03-May-2005, 00:14
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
To check which eprom is fitted, lift the seat to reveal the ECU - large silver box about 6" by 4"
There would originally have been an anti tamper sticker covering a large rubber bung in the top - this will probably have gone.
Remove the bung & have a look inside.
If you have no experience with electronics, keep your fingers out of the way - you could unwittingly cause damage in there if you prod around.
Directly below the hole, you will see the eprom which should have a sticker on it telling you exactly which version it has fitted.
[Edited on 2-5-2005 by Rushjob]
Old 03-May-2005, 04:32
Ok, will look. Looks as if it has been tampered with. Also, speedo cable is broken off at bottom by the fork. Is this common, or maybe intentional? I had my F2 one snap in the same place, but...I am weary about this bike already. Safety wire, low miles, broken speedo cable, numerous scuffs and scrapes, brand new tires, etc. I hope I didn't just buy a piece of ****. I'm having it checked out this weekend.
Old 07-May-2005, 22:03
DC's Avatar
DC DC is offline
Mood: Double 9, Single 6.
Chill pill bro
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:28.
