Old 03-May-2005, 15:40   #1
851neil 851neil is offline
Mood: need a bike...
P7 vs P8
Ok can anybody tell me how to tell the difference between the P8 and P7 ECU ?? I need to check which ECU is fitted coz if it's a P7 I'll be chasing after a P8.
cheers
Neil
Old 03-May-2005, 18:11   #2
paynep's Avatar
Mood: Wet wet wet
What's the number on the sticker, or stamped on the mounting lug?
Alternatively, if you're feeling adventurous, whip the lid off and find the clock chip - if its 4.000Mhz it's a P7, if its 8.000Mhz its a P8.
Hope that this helps
Old 03-May-2005, 23:48   #3
the number on the sticker is:
WU43.07/20A.20
Old 03-May-2005, 23:53   #4
paynep's Avatar
Mood: Wet wet wet
99.99% sure that's a P7 as its almost identical to the number of the ecu on my 851, which has an FIM chip, open airbox and a 50mm full system on it.
[Edited on 3-5-2005 by paynep]
Old 04-May-2005, 00:55   #5
My 916 (that has a P8) has an under-seat sticker that reads: Engine Family: SCG.92P8GARA
Old 05-May-2005, 20:59   #6
so does anybody know if the 916 P8 ecu is compatable with the 851 ?
I've been told that it's a straight swap but I'm not sure if the unit from a 916 is the same size etc ??
Can't you tell I'm new to Dukes !!!
Old 07-May-2005, 03:42   #7
Ducman851 Ducman851 is offline
Mood: Just Ducky
Well the P7 is your basic FI computer, with the P8 you can get rear cylinder correction.
I have a P8 on my 1990 851 Strada and what a differance it made. Smoother power over entire rev range, better idle. This is possibly due to map for 888 that I had made as a starting map is closer to bikes actual needs. My P8 came from a 1998 Laverda 668 Ghost that I parted out, and was a straight bolt in.
If youd like I can get some pics tomorrow of the side by side of them.
[Edited on 7-5-2005 by Ducman851]
Old 07-May-2005, 08:13   #8
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
I think you can swap them but you'll need a P8 chip for your bike. They come up on E-bay but I'd get one from JHP so you know exactly what you've got.
Rgds, Rob
Old 07-May-2005, 16:53   #9
Mike Cecchini Mike Cecchini is offline
Mood: Like a rolling stone......
Note on P7 vs P8 ECU's:
All 851's and 888's up to serial #'s 000508 have P7 ECU's.
888's from # 000509 onwards have P8 ECU's.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:21.
