General Motorcycles only
Old 09-May-2005, 20:02   #1
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Brembo Radial master cylinder spares
Help !
Does anyone know a good brembo stockist where I can get spares for my radial brake MC ?... I need a new washer as someones clouted the lever forward (probably 'er indoors trying to get at her gardening tools!!) and bust it (its supposed to break under duress apparently ??). Spoke to PDQ but they havent phoned me back...
Also..its booked in for a MOT Friday...dya reckon a tester would fail it if the levers flopping forward ??
Many Thanks
Nat
[Edited on 9-5-2005 by Nattyboy]
Old 09-May-2005, 20:57   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Nat,
http://www.motomeccaspares.com/
Try these guys or GP Racewear at Silverstone - UK importers I think.
Rgds, Rob
Old 09-May-2005, 21:05   #3
Mark Mark is offline
Mark's Avatar
Originally posted by Nattyboy
Help !
Many Thanks
Nat
You've changed your tune Nat, you said you did it walking past!
[Edited on 9-5-2005 by Flanks]
Old 09-May-2005, 21:14   #4
crust crust is offline
Mood: :( broken
If meccas havent got it then these people are the importers
http://www.ecparts.co.uk/
Crust
Old 09-May-2005, 21:16   #5
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
i had the same problem before and used this site
http://www.sir-corse.de/
Old 09-May-2005, 21:18   #6
Rob B's Avatar
Crust,
All the EC parts guys are now at GP Racewear. (although the EC site still works you can see they are now part of the GPR group) Spoke to the Steve's earlier this week.
Rgds, Rob
Old 09-May-2005, 22:45   #7
Felix Felix is offline
I think you'll find that GP Racewear will not sell you parts. They will, however, service and repair your radial cylinder, provided you send it to them. I had the exact same problem, recently. Eventually, I found some repair kits at PDQ. There are other sources such as Yoyodyne in the States and RedRacing parts in Italy.
Old 10-May-2005, 11:40   #8
Nattyboy's Avatar
[Edited on 9-5-2005 by Flanks] [/quote]
...ahem.....
Old 10-May-2005, 17:24   #9
RedRacing won't sell spare parts for master cylinders. They say on their website that you have to send it to Brembo via them for servicing. It makes sense really, it's a big liability issue if you install a critical part incorrectly and get a brake failure.
Old 10-May-2005, 17:49   #10
I know what you're saying Shazaam, but that little top hat washer breaks easily when you knock the lever. I've replaced it at least twice myself and it's an easy job. The repair kits are about 30-35 pounds and for that you get the pushrod, the circlip, the "top hat" washer, and a tube of grease. If you take care, you can do the entire job without disturbing the hydraulic system, i.e, no need to bleed the system.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
