Old 08-May-2005, 15:47
snagger snagger is offline
Low speed throttle response.
Hi, posted this on UK Mon with no response...
'01 M600 when started cold, fires straight up, and seem's to rev hard when on choke, try to back the choke off, the engine then struggles to idle till warm, or rev's high with choke.
Before fully warm the bike has a low speed 'stumble' when pulling away, this is noticable, to a lesser degree when fully warm too.
The bike is totally standard.
Is there any way to fine tune the jetting to eliminate this?
I'm thinking maybe pilot screw's, how many turns out are they as st'd?
Are they a bit rich or lean as st'd?
Any help appreciated.
Regards Phil
Old 08-May-2005, 17:43
Jon's Avatar
Jon Jon is offline
Mood: Tad more confident
Not sure if this will work with the monnie 600, but you couold try a smaller front sprocket. This smooths out the jerkyness on the 748/9** series
Old 08-May-2005, 22:19
Hi, I've got a smaller sprocket fitted, which as you say help's.
The bike still suffers from a 'stumble' just off throttle tho.
Phil
Old 08-May-2005, 22:39
Jon's Avatar
Jon Jon is offline
If you can hang on a bit Nelly will be back soon. I'm sure he can help you
Old 09-May-2005, 22:20
Ok, Thanx,
Phil
Old 11-May-2005, 06:36
Ducman851 Ducman851 is offline
Mood: Just Ducky
You could back the pilots out abit, stumble is usually indicative of a lean condition.
Also, how many miles/kms ?
Old 11-May-2005, 19:31
Bike has only done 5500mls, everything is stock.
I was figuring it may be a tad lean by the temperemental cold running.
Do you know how many turns out the pilot screws are as standard?
Just so I have a base to work from (tried one screw, think it was about 3 turns to fully seated)
Thanx, Regards
Phil
Old 11-May-2005, 23:30
psychlist's Avatar
Mood: Lucky? For some, maybe!
You need a stage 2 dynojet kit & hi-flow air filter
The transformation to low speed pick-up is phenomenal
www.spareshack.co.uk
Old 11-May-2005, 23:32
phil_h's Avatar
phil_h phil_h is offline
Adjust the pilot screws to 6 turns out IMMEDIATELY !!!
You will def get a smoother running bike, cos the std settings are WAY too lean.
Old 12-May-2005, 23:55
Ahem, is that SIX turn's out!!!!
Is there that much threading....
What about the midrange, is there a benefit from lifting the needle's too?
Six turns....
Thanx, Phil
Six turns (recurring)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:40.
