General Motorcycles only
Old 16-May-2005, 16:09   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Fixing fairings
First off a big THANX to Tim for the fairing.
Anyone got any sound advice, problems/solutions/experiences to fixing pannels.
Old 16-May-2005, 21:23   #2
Carbon749's Avatar
Mood: I own a flame thrower
Are we talking, plastic, glass fibre or carbon. What is the damage and are you planning on painting it afterwards?
Old 16-May-2005, 22:34   #3
dave996's Avatar
Mood: Fed up...
Its glass fibre, photos will follow shortly and damage wise we are talking a hole and a few cracks, and it will be painted afterwards.
Dave
Old 16-May-2005, 23:13   #4
Carbon749's Avatar
Two ways that I know of.
Most car shops will now sell glass fibre matting and cold cure two part resin. Wet lay the glass fibre matting on the back of the crack / damage and make sure there is plenty of overlap so as to reinforce the damaged area. On the front side use the resin to fill the damage and sand it back, if the crack is too large then fill with normal car filler. All ready for painting.
Alternative is to find a local manufacturer of glass fibre components, not necessarily fairings, and offer them some beer money to sort it out for you.
Old 16-May-2005, 23:19   #5
Lily Lily is offline
Mood: stiff and tired
send it to me i am a whizz at fixing bodywork....
as long as you dont want it looking pretty mind
Old 17-May-2005, 11:04   #6
dave996's Avatar
Mood: Fed up...
On the back of the pannel it has been painted, does that require roughing up or will the new glass fibre bond to it still?
Old 17-May-2005, 18:30   #7
dave996's Avatar
Mood: Fed up...
Cheers for the offer Lil, but I'm going to give it a go myself. Can't wait to get plasered in glass fibers
Old 17-May-2005, 18:40   #8
I'd be tempted to get some fairly low grade sandpaper on the inside just to give it a good key to grab hold of as such. Think most of the process has been covered by the sounds of it above.
Old 17-May-2005, 19:51   #9
Carbon749's Avatar
Yep, abrade the surface to give the new glass and resin a good key ..... basically sand the surface back to remove any shine, silicone etc just as you would if you were painting the surface. After sanding wipe the surface with a cloth and thinners to degrease the surface prior to applying the glass and resin.
Old 17-May-2005, 20:07   #10
dave996's Avatar
Mood: Fed up...
Cheers for all the sound advice ladies and gents, will let you know how I get on.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:27.
