Old 20-May-2005, 21:59
Wylie1's Avatar
Wylie1 Wylie1 is offline
Termi can/ filters fitting
I'll be fitting them tomorrow. Anything special I need to know before I start out?
Old 20-May-2005, 22:09
Mark's Avatar
Mark Mark is offline
The hook off a coat hanger!
Old 20-May-2005, 22:58
swannymere's Avatar
Mood: High as a kite!
Record everything you do with digital camera!Wish i had.
Old 20-May-2005, 23:13
Wylie1's Avatar
A bit more info required please
Old 20-May-2005, 23:18
keefer's Avatar
keefer keefer is offline
let me get this right your changing the cans and putting in some filters yea
Old 20-May-2005, 23:21
Gizmo Gizmo is offline
Mood: is it the weekend yet??
take sub frame off it makes it easier to remove old can, get new can into position then replace sub frame so you can check it goes in right place, leave everything loose and tighten fgrom rear forward. if its a 57mm full system 2:1:2 make sure you have plenty of valium to hand
Old 20-May-2005, 23:22
The can, no worries, maybe a length of wire to hook around the two springs holding the pipes in to the can, to release them? and..dont forget the gaskets that go between the pipes and the can!
Now the air filters. Be very carefull with the bolts that hold the air tubes to the air bow. Dont cross thread them!
Old 20-May-2005, 23:25
keefer's Avatar
well i wouldn't remove the sub frame but just undo the bottom two nuts and slacken of the top two then leaver it up, you can then access the cans.
firstly though remove the seat then tank so you can put your trick filter in
Old 21-May-2005, 00:28
A common problem is that a newly-installed exhaust pipe or slip-on doesn't fit properly which causes the bike to backfire on decelleration. Aftermarket pipes are not a precision fit and often they let in combustion air that, when mixed with unburned fuel, results in the fuel being burned in the muffler. To prevent this, use a high temperature silicon sealant at the joints to keep the air out.
I recommend Permatex Ultra-Copper high temp RTV silicone gasket maker #101BR for the aftermarket slip-on system joints. Good to 700?F intermittent. Available in auto parts stores.
http://www.permatex.com/products/pro...tem_no =81878
Old 21-May-2005, 11:14
iang's Avatar
iang iang is offline
I found the most awkward part was fitting the ecu unit, the first one i did on my brothers old bike had us fiddling for about an hour before we realised that the plugs that go into the ecu were on a cam and not just a push/pull fitting !
It is not that it is hard to fit just awkward to get into as the wiring and battery cables do not have much slack to enable them to be pullled out more.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:38.
