Old 31-May-2005, 07:45   #1
Exjaapie Exjaapie is offline
Mood: Pretty good
Fuel leak
Hi all,
I have a '96 748, absolutely love the machine, although recently I have aquired a petrol leak.
I discovered this when the bike was parked up on it's side stand. Even when she is on the pit stand, there is a leak. I have taken off the fairing to attempt to find the source.
Before I start stripping the bike down, has anybody else out there had a similar problem?
Old 31-May-2005, 08:24   #2
moto748 moto748 is offline
Whereabouts are you seeing the leak?
Drips on the floor?
Staining on the engine casings?
I had the latter (visible on the rear cylinder), and it turned out to be no more than a frayed fuel pipe connection under the tank.
That'd be my first port of call.
Old 31-May-2005, 08:32   #3
Mood: Pretty good
Hi,
first I noticed the puddles on the floor, after stripping the body work, there are drips of fuel on the exhaust at the back of the engine block.
Old 31-May-2005, 08:45   #4
gasmanrus gasmanrus is offline
Mood: childish
g'day mate
has the fuel tank been off? i had a problem with my bike after i removed & refitted the tank. underneath the tank there are 3 quick release type valves & the one of the o rings to these become damaged & let fuel by.
also when i have filled the tank completley & put the bike on its stand fuel has leaked from the overflow (breather?) pipe
Old 31-May-2005, 08:48   #5
Mood: Pretty good
G'day,
Yup, the overflow was the first thing I thought about, no joy. I will have look under the tank for corroded pipes or o rings....
Thanks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:21.
