Old 09-Jun-2005, 06:50   #11
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Originally posted by Harv748
So if the regulator is/could be OK, what was the actual cause of the problem? The wiring, bad connector(s) block???
Hello
Harv748 I had the same problem, and as Shazaam states replace the wires with higher gauge, got mine in Mapplins, I replaced the wire to the regulator, but not yet all the way through to the alternator, but intend to.
Also used bullit connectors, and heat shrink.
I was also worried I may have damaged the regulator, but I found my wires were burnt out at the connection block, which I have cut out.
I would say you should be ok though. If you need any wire, connectors etc, let me know.
regards
TopiToo
Old 09-Jun-2005, 10:25   #12
Harv748 Harv748 is offline
Harv748's Avatar
You've got a U2U topitoo
Thats what I'm hoping Weeksy...last tme I had a rectifrier problem...it cost me over £1300! (Wireing loom/Bat/tray/blah blah blah).
Old 09-Jun-2005, 15:55   #13
Bikes: 748ish . .
Hello
Harv748 replied to your U2U,
regards
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:44.
