Old 05-Aug-2003, 07:38   #11
Flanners Flanners is offline
Now shifting into neutral when rolling to a stop, saves all the hassle!
Old 05-Aug-2003, 08:37   #12
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
I\'ve got loads of spare neutrals that anyone can have!!!
I seem to find them everywhere and all of the time!!!!
So if you're looking for a neutral please let me know as I'll gladly let you have one of mine!!!
Tim:ro ll:
Old 05-Aug-2003, 09:52   #13
rcgbob44's Avatar
Nelly`s 100% correct!
Just bleed the clutch line, I get the same effect on the Jota if i get air in it.
Old 05-Aug-2003, 14:12   #14
thrustercat
Nigel, with my duke I have noticed that you have to give it a solid, but gentle nudge up from 1st before you find neutral. I jumped on a Blade the other day, and couldn't believe how easy the gear changes was, as well as the comfort level.... a good reason for buying another bike!! I
I have also noticed that my foot begins to ache after a while due to the gear changes... perhaps it's my boots, or I need to change the positioning of the gear lever... I will investigate at some later stage.
Sticky - have the same problem at lights... gets to the stage where apathy kicks in and you find it easier to whack the buggr in first and hold the clutch in.
Skidlids - just had a full service on my duke, picked it up last Sat.... £650 notes in total, including replacement clutch plates. My plates must have been slipping for quite some time as I have noticed that the bike now performs extremely well. So much more torque it's unbelievable. Glad I had them replaced. Looking to get a milled clutch cover as I hear this extends the life of the clutch.
Flanners - never tried finding neutral when it motion, I know on occasion that the bike goes into Neutral... must give it a go.
Old 05-Aug-2003, 15:18   #15
Think I had one of your neutral the other month at Oulton Rattler.... you can have it back if you like....
It gave me a nasty case of gravel rash
Old 05-Aug-2003, 15:58   #16
jim flynn jim flynn is offline
Mood: Mellow Yellow
Absolute nightmare getting neutral. My 748 wasn't too bad until i had the clutch, chain and sprockets replaced. Since then i have had to employ the select neutral while rolling method.
Had a strange thing happen sunday night. After a downchange i found the clutch not working till the last 2 cm of travel in the lever. Gear changes became very difficult and neutral? No chance. Got back and rotated the span adjuster and got the clutch back. Can't explain it. The downchange may have been before the clutch was disengaged so maybe some feedback through the system span the adjustor somehow? Damned if i know.
Funny how with the engine off you can get neutral straight away and yet with the clutch all the way in you are left working your left foot like a tap dancer trying to find it.
Old 05-Aug-2003, 16:02   #17
Jim,
Could be a few things.... clutch fluid, air bubbles, possible leak in the system, or maybe your clutch drum nut has worked lose, happened on mine, and couldn't get neutral full stop, not even when not running, had to ride home (120 miles) in 1 gear !!
Old 05-Aug-2003, 17:05   #18
Elusive Neutral
An elusive neutral, really a clutch disengagement problem, is most often caused by air in the hydraulic system. Any air in the system will be compressed and this will prevent the clutch plates from separating enough and allow them to touch and drag. It's this slight dragging that makes it difficult to slip into neutral while stopped. It also causes premature clutch wear.
The stock slave cylinder hydraulic ratio is designed to give a lot of leeway when it comes to bleeding, meaning you can have a lot of air trapped in the system and it will still work (at least partially), but that's why the pull effort is so high and why neutral can be hard to find when there's air in the system.
If you have not already done so, you can make bleeding much easier if you replace the banjo bolt at the master cylinder line connection with a bleeder-type banjo bolt. The master cylinder is where most of the air rises, gets trapped, and cannot be bled out (easily) using the bleed nipple down by the slave unit.
If you've installed a new clutch pack, drag-free operation requires that the metal plates be the correct thickness and absolutely flat, and that the overall height of the clutch pack not exceed specs.
On a bike with an original clutch and slave cylinder, a problem finding neutral will (almost always) be solved by bleeding air from the hydraulics.
For the rare case when purging air from the hydraulic system doesn't work, a clutch disengagement problem can be helped by increasing the clutch pushrod stroke distance.
The best way to do this is to change the clutch lever pull distance by changing the 4-position adjuster (early models don't have adjustable levers.) This is often necessary either after installing an aftermarket force-reduction clutch slave that (always) reduces clutch plate separation or after installing new clutch plates. There are four lever settings; where position 4 produces the least clutch plate separation, position 1 the most. This adjustment will also change the zone where clutch engagement begins.
Adjusting Master Cylinder Stroke Volume
Another way is to change the stroke volume (of hydraulic fluid) produced by the clutch master cylinder by adjusting the screw (covered by a hot-melt glue in later years) located between the clutch lever and the handlebar grip. Increasing the stroke volume will increase the clutch pushrod stroke distance and consequently the clutch plate separation.
You can increase the stroke volume by turning this screw IN about a half-turn. Mark its initial position for future reference. If you go too far, the master cylinder will not bleed back properly.
So, turn the adjustment screw OUT to move the clutch engagement point closer to the grip, and turn it IN to move it out. Remember to leave some play in the end of the lever after you're done, or you'll wear the clutch out prematurely.
A word of caution here. The reason that there is a factory seal over this adjustment screw is that it's not intended to be used as a service point for clutch adjustment. It's used by Brembo during final assembly to locate the clutch master cylinder piston in the proper position relative to a hole that allows the hydraulic fluid to return to the reservoir. Small changes here can make clutch function erratic and remove too much lever free-play.
Old 10-Aug-2003, 03:04   #19
Mood: Mellow Yellow
Some excellent advice here. I first put the clutch lever at position 1 which did help a bit but not enough. Next i got the Haynes manual out and spent a few quid in Halfords on top quality Castrol Dot 4 and a bleeding kit. Spent a pleasant afternoon sweating in the sun learning how to bleed my clutch.
The fluid had been in there about 18 months or so and was a bit grey looking. Ran the new fluid through and gave it a squeeze which was definitely an improvement. Checked externally for any signs of leaks and then went for a quick 20 mile test ride.
Had the familiar pain in my left hand from the heavy clutch, actually a good sign! Real test was at a roundabout with lights at every exit which were all red when i got to them. Started with the rolling slip in to neutral which was fine. Next, full stop down into first and snicked into neutral nice and easy! Hasn't been that easy for 2 years! New skill learnt and the bike is better than ever. Happy little biker!
Old 10-Aug-2003, 13:57   #20
Bled it
Bled it and then put the reach dial on number 2 and hey presto neutral when I want it. Never occured to me that the lever reach would effect the plates?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:33.
