Old 21-Jun-2005, 21:30   #1
Chef Chef is offline
Bikes: 998S Chili trackbike,749R (corse kit), 748SPS
Chef's Avatar
Mood: Flange - it's a state of mind....
998s Mono Shock Spring
Could any of you who own the rare beast that is the 998s mono what spring they have in the Ohlins shock - mines a 998s bip with a single seat & the shock felt a bit too hard at Brands today
Apart from that it's the best bike I've ever ridden!!
diablo corsa's worked well (feel not as good as rennsports) with a 190/50 (245mm ride height) but I have mag wheels on it so the turn in is very quick compared to 748sps
Not sure about the 15/38 gearing - might try 14/38 for better drive in 2/3/4?? - anyone tried this??
Still in one piece - which is nice - 6 out of 7 sessions red flagged - it was GSXR1000/R1 carnage!
Thanks
Old 21-Jun-2005, 23:54   #2
rcgbob44's Avatar
Chef
I`ll check mine tomorrow and let you Know.
Bob.G
Old 22-Jun-2005, 21:17   #3
Chef's Avatar
Thanks Bob
Old 23-Jun-2005, 00:12   #4
Bungi Bungi is offline
are you running a standard rear sprocket ? i just though from memeory that std rear was 36t, but perhaps youve changed it?
i changed mine to 14 front and found it better suited the gearing to trackdays and then went up one at the rear also, i think its 14 /37 now
Old 23-Jun-2005, 01:15   #5
BDG BDG is offline
BDG's Avatar
Std gearing on 996R which is pretty much the same engine as the 998S is 15/36.
I have dropped to 14/36 which is much better and when chain is replaced will change that to 15/38 as its kinder to the chain with the larger 15 tooth front sprocket.
[Edited on 29-6-2005 by BDG]
Old 23-Jun-2005, 08:34   #6
can you get away with that 15/38 arrangement ok with std chain size?
Old 23-Jun-2005, 11:05   #7
BDG BDG is offline
BDG's Avatar
No i believe you need a longer chain, hence i'm waiting for chain to be replaced before going to the 15/38
Old 23-Jun-2005, 19:08   #8
Chef's Avatar
I think the std gearing is 15/36 for a 998s (renthal guide)
I've got a renthal quick release unit (150-200ish) & longer gold did 525 chain
I'm not sure I like 15/38 still a bit fluffy in slow traffic in 1/2 as my 748sps is before I went up 3 at the rear
Thinking of 14/38 but not sure if it'll make the power a bit on/off in 2nd on the track???
anyone tried it - whats 14/37 like??
Also was amazed how little engine braking there was going down from 3 to 2nd at Druids - felt less than my 748sps!!
Old 26-Jun-2005, 06:01   #9
Go Galfer Go Galfer is offline
15/36 is OEM for 998s
Old 26-Jun-2005, 09:04   #10
Henners Henners is offline
That's more likely to be the fueling Chef - get someone with a dyno like Moto Rapido to set it up for you, they will amaze you with what a difference it'll make. The engine isn't as smooth low down with 50mm Termis and open CPU because it is usually running way too rich - look for carbon coating on the exhaust trumpets - and needs setting up. Runs far nicer IMHO on standard cans and CPU even though you lose 8bhp at the top end I never missed it on my 998FE and am leaving the 996R as it is for now.
The lack of engine braking compared to what you're used to is down to the shorter stroke engine being easier to turn over. Try an original 916 for vicious engine braking
[Edited on 26-6-2005 by Henners]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:45.
