Old 24-Jun-2005, 15:34   #1
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
Bleedin brakes
Went to track day. Progressively lever lost feel and finally pulled back to bar.
Bled brakes with me mityvac. Went fine but no change. Bloke came along and seemed to open the bleed nipple very slightly, pull back the lever, close the nipple. He repeated this about 20 times. Result rock hard brake lever for rest of day.
Can anyone confirm what he was doing and why it made the difference it did?
I did not watch closely enough...git.
Old 24-Jun-2005, 15:38   #2
guest1 guest1 is offline
That's normal for bleeding brakes innit? Except I've only ever seen it done that way when no tube was available and we needed to get my mate off the motorway.
Old 24-Jun-2005, 16:37   #3
Felix Felix is offline
Yup, done this myself a few times. I usually use the vacuum pump method as well, but every once in a while the last bit of air won't come out, and then pushing out the air with the lever seems to work well, especially at the master cylinder. Just make you ALWAYS close the nipple before releasing the lever.
Old 24-Jun-2005, 17:32   #4
Mr_S Mr_S is offline
That's why I fitted speedbleeders to mine, instead of buying a mityvac.
Process is basically
squeeze lever
open bleed nipple slightly
When lever runs out of travel, close nipple
release lever
repeat until done, then swap sides. Using a piece of clear hose lets you see if there's any air bubbles coming out, and keeps the area clean of fluid.
Strangely enough, I've just bled mine with 5.1 this morning. Had a problem on a trackday with the reservoir hose kinking and not allowing the M/C to fill, so got progressively more lever travel until it was spotted. Hose is now braced...
Old 24-Jun-2005, 17:42   #5
smilo006's Avatar
Cheers. Felt like a muppet for asking really. As usual however answers are informative and helpful.
Old 24-Jun-2005, 20:46   #6
nathanTX nathanTX is offline
Very normal way to bleed brakes. I only use a pump when I'm doing something major like swapping the calipers out or installing new lines or something. I always finish with manual bleeding as you describe. You can also get the last little bit of air out by putting a zip tie squeezing the lever overnight. Just run it around the lever and the grip and pull it until it's firm (but not so tight that it gouges the grip or anything). In the morning, do one last squeeze/loosen/tighten/release.
Old 25-Jun-2005, 00:58   #7
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
Yep thats the way to bleed with no hose/anti return valve.
Old 25-Jun-2005, 14:23   #8
sharpo sharpo is offline
sharpo's Avatar
Mood: Big bill-money well spent
Yes the best way without doubt, just time consuming.
Old 25-Jun-2005, 20:16   #9
moto748 moto748 is offline
Ha! Having bled my back brake with my mityvac this afternoon, and got it rock-solid, thought I'd try this short-cut method on the front, which wasn't *quite* as good as it could be.
Little bit more, little bit more.....
Soddit! Got air in the bloody thing: lever coming right back to the handlebar with no resistance whatsoever.
Oh well. Thought this meant I'd better do the damn job properly. So off with fairing and nose-cone. Not essential, I know, but I prefer it cos it makes access to the reservoir cap and the master cylinder bleed nipple a breeze. The master cylinder bleed nipple in particular I always find a right pig; the throttle cable always gets in the way.
I bled and bled and bled, and now it's better than ever.
I think part of the trouble is the bleed nipple's a bit worn; the hexagons are rounding off a bit, making it difficult to tighten. I'm sticking to using a ring spanner in future.
Must remember I'll get a new nipple fitted at the next service.
[Edited on 25-6-2005 by moto748]
Old 26-Jun-2005, 01:17   #10
Just get these
http://www.speedbleeder.com/
I swear by them.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:45.
