Old 01-Jul-2005, 17:30
khu996's Avatar
khu996 khu996 is offline
Removing tank guard
I've removed the standard rubbery tank gaurd to fit the carbon one I bought off Dave (cheers mate!). The standard pad came off easy enough, but whatever Ducati used to stick it on in the first place won't budge.
I've tried soaking it in WD40, heating it, pulling it off with my nails (!), but I can't get rid of the little black strips!?
I've tried offering up the carbon tank pad with these strips still in place, but it makes the pad sit too far off the tank.
Has anyone else replaced the pad, was it any easier, or am I making this hard for myself?
Old 01-Jul-2005, 18:45
Wylie1's Avatar
Wylie1 Wylie1 is offline
I thought the carbon pad sat on top of the standard pad. Could be completely wrong though as I haven't fitted one.
Old 01-Jul-2005, 20:28
chris999 chris999 is offline
Mood: red and proud !!!!
you do not "heat it" too much then
you need an alcohol base cleaner such as acetone and elbow grease,
be careful not to get it on other plastics (it will attack and discolour) i learnt the hard way !!!
might be worth taking seat off.
Old 01-Jul-2005, 20:45
pedro's Avatar
pedro pedro is offline
Mood: r
i watched jhp take mine off,cut the pad out with a stanley knife blade,its the stuff they use on windscreens.as you wont see it under the new cover,i would use a stanley knife,by heating the blade a little it should come away easy
Old 01-Jul-2005, 21:03
khu996's Avatar
Using a stanley knife scares the sh*t out of me, worried I might make a mistake and take a chunk of paint out!
Chris, I've got some paraffin, will that do?
Old 01-Jul-2005, 21:41
pedro's Avatar
Mood: r
as a carpet fitter its my main weapon,by heating the blade it will cut away like butter,it wont be seen as you cover it with new item? take your time, oooohhhhhhhhh give me a knife
Old 01-Jul-2005, 23:07
parafin would do ,, meths is my tipple of choice if you can't get acetone (same warning.. )
Old 01-Jul-2005, 23:27
guest1 guest1 is offline
Meths
Old 02-Jul-2005, 11:48
methalated spirits - that purple stuff b&q garden centres any hardware shops.
Old 02-Jul-2005, 13:48
Bionicle's Avatar
Bionicle Bionicle is offline
Or in a brown paper bag you can blag off some wino under most railway bridges
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:00.
