Old 12-Jul-2005, 14:36
Il Pres Il Pres is offline
[Ebay] Termignoni
Will this fit a 999MY05 bip?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=7986352470
Thanks,
Il Pres
Old 12-Jul-2005, 14:49
Gizmo Gizmo is offline
Mood: is it the weekend yet??
not according to DPP parts book, its 04 or earlier model 999 specific
Old 12-Jul-2005, 15:11
Twinfan's Avatar
Twinfan Twinfan is offline
That's because of the new swingarm on the '05s. The front pipe won't clear it. I'd also guess the ECU won't be suitable either, but you could use a PCIII instead.
Old 12-Jul-2005, 15:12
Swingarm is the big issue...
Old 12-Jul-2005, 15:21
is wheel clearance under the can also an issue?? if not you could get can and buy 05 link pipes individually
Old 12-Jul-2005, 15:22
Mood: going for a ride...
...and I think I'm right in saying that all 999's are now the deep sump engine (?) so the front pipe in that system will not only hit the swing arm , it will also hit the sump.
As stated above , the ECU will probably be be no good , you could run with a PC or just use the standard ECU.
If you can buy it cheap enough it may be worth it for the silencer / carbon cover and air fillters , a front pipe to suit the deep sump and fabricated swing arm is around £150 inc VAT which is all you would really need to make it fit.
Old 12-Jul-2005, 15:33
Twinfan's Avatar
Yep - the link pipe and ECU are the problem. The box, cover, filters etc will all fit OK. TO make it worthwhile:
PCIII - around £300
Setup - around £100
Link pipe - around £150
That's £450. An assymetric Termi set is around £1000, so you'd want to get the one on eBay for around £350ish to make it worth while for you. Can't see that happening to be honest.
It'll go to someone with an '03 or '04 year 999 for around £700 or so. They can just bolt it straight on and use the ECU too
Old 12-Jul-2005, 21:54
Brogins's Avatar
Brogins Brogins is offline
Mood: PENSO POSITIVO....SEMPRE!!
..No that I need more HP or speed, but of course, I like the idea and the noise of a Termi set. ..Anyone around that has already fitted a 05 999 BIP with a termi system? is it a bolt off/on modification (with the ECU also) or the rear frame needs to be adjusted?
Pricing and a dealer that knows what is doing? - no e-bay for me...
Thanks guys
Old 12-Jul-2005, 22:05
I heard that Termi's to fit the '05 bikes are in short supply.Thankfully one comes in the box with the 'S'.
Old 12-Jul-2005, 22:17
sye73 sye73 is offline
So guys,can I confirm that you're saying the Termi can isn't what makes the asymetric kits model specific,it's actually the ecu+front pipe? If that's the case (and it does seem to make sense),then a 749/999 series can should fit anything from a 749 bip to a 999R on the assumption that the pipe (and ecu) are changed.......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:44.
