Old 27-Jul-2005, 22:22   #1
748IOM 748IOM is offline
Mood: Yellow!!
F\'ing alarm!!
Anyone know how to remove or disable the factory alarm fitted to a 748?
My keyfob decided to not work this evening when I wanted to take it out, thankfully at home!! I stripped the keyfob to see if moving the battery round would enable it to work, it didn't make any difference, then all of a sudden the bloody alarm went off, it wouldn't stop so I disconnected the battery connection to the bike, it carried on going off which means I can only assume it has some form of internal battery??
It has since stopped after annoying the neighbours for a little while.
I live on the Isle of Man and so bike theft isn't quite the same as the UK mainland not that an alarm would really make much of a difference anyway, so does anyone have any instructions of how to remove or disable it??
Thanks
Old 27-Jul-2005, 22:24   #2
Harv748 Harv748 is offline
Harv748's Avatar
Rip the fooker out...just have my datatool after I missed halve of TA4 because of it playing up.
Not as difficult as I first thought...just follow the wiring through and unsplice everywhere it has been joined to.
Old 27-Jul-2005, 22:32   #3
Gaz 748's Avatar
Remove it you dont need it
Old 27-Jul-2005, 23:00   #4
Mood: Yellow!!
I know I hate alarms they give me nothing but grief but its a factory fitted one with an immobiliser so its a bit more involved to remove.
Just wanting to know if anyone has removed one to make life easier?
Old 28-Jul-2005, 00:01   #5
Ian 748 Ian 748 is offline
Ian 748's Avatar
Perhaps it had gone into sleep mode or some such. My Meta needs the ignition to be turned on and off before the key fob will work in this mode??
Old 28-Jul-2005, 00:46   #6
Mood: Yellow!!
Maybe but its never done it before and after the alarm started kicking off I don't want to go near it now its finally shut up. I'd rather rip the thing out, I can just see it giving me more grief than its worth. I already have to carry the fob separately from the ignition key so it doesn't get trapped in the steering damper.
Old 28-Jul-2005, 22:08   #7
Bungi Bungi is offline
if i remember correctly they are pretty simple to bypass, but it will go off while you carry out the procedure of unplugging bits and disconecting the power source.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:45.
