General Motorcycles only
Old 05-Aug-2005, 00:54   #1
yorkshire pud yorkshire pud is offline
Mood: poon tang
slipper clutch???
i have a 4 post slipper, bought ebay. ? how many plates should i have. do i start with a frition plate. and last to go in is a steel, plate. .
Old 05-Aug-2005, 01:30   #2
Depending on the type or manufacturer of the clutch pack you could have 7, 8 or 9 friction plates.
The more important factor is the pack width. Build the pack up on the bench and then measure it's thickness. You want 35.5 - 36.5mm
Use different steel plates to get the thickness. They are available in 1.5mm and 2mm.
Use a friction plate first, then alternate them. Finish with a steel plate under the pressure plate.
You could end up with two steels going in last depending upon the number of friction plates.
Old 05-Aug-2005, 01:44   #3
Mood: poon tang
cheers nelly.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:30.
