Old 10-Aug-2005, 09:44
ttstu ttstu is offline
Mood: On the mend!
Chip Removel
Is this really a slot out slot in job? Is ther anything I should be aware of? Will the bike start afterwards?
Old 10-Aug-2005, 11:52
Mood: me in a mood? NEVER!
what on?? dont think you can on the 749 or 999 but I have been known to be wrong. easy on the 748 916 etc just be carefull not to bend the pins when pushing the chip in.
Old 10-Aug-2005, 12:14
bolds bolds is offline
When you change the cpu on 749/999 you have to remove all the battery box and components -all the wiring is very tight so its a bit of a fiddle -also when cpu is unplugged the throttle position sensor has to be reset and thats a dealer only job with diagnostic kit
Old 10-Aug-2005, 13:02
Mood: going for a ride...
bollox
...........but you are right about where it is and how to get it out
Old 10-Aug-2005, 19:26
Mood: On the mend!
So once I've stripped down have the bike it's just a swap job and she should start?
Old 10-Aug-2005, 20:21
nathanhu's Avatar
nathanhu nathanhu is offline
Mood: head down
yep but dont use the red key..........
Old 10-Aug-2005, 21:50
bollox
Quote from workshop manual " When changing the throttle body,and or the throttle position sensor,or the engine control unit,or the section of wiring connecting these parts,it is necessary to carry out a new TPS reset procedure"
Old 11-Aug-2005, 08:18
ah well , my old 999S , the wifes 749S and my current 749R must not have read the workshop manual then , all 3 have had the CPU off and swapped for a race CPU and swapped back again with no problems
Old 13-Aug-2005, 12:13
Mood: On the mend!
Well fingers crossed then.
Old 13-Aug-2005, 20:35
gimpboy450's Avatar
gimpboy450 gimpboy450 is offline
Mood: crank it and bank it
chip removal
to carry out a new TPS reset procedure'
How do you perform this TPS reset??/
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:18.
