Old 30-Aug-2005, 12:05
loverobot's Avatar
servicing a 96 600ss
How often are the belts to be checked/changed? had mine done last september - is it annually / 2 yearly?
i am away from home at the mo and thinking whether need to book her in...........
Old 30-Aug-2005, 12:18
phil_h's Avatar
phil_h phil_h is offline
Std 2v ducs only ever need their belts changing 2-yearly, and that gives a very big safety margin.
If you keep the bike out in the sun so it gets temperature-cycled a lot then the rubber degrades (same as your tyres will !) but thats the only tripwire I know of, and its prob only bad in italy
Old 30-Aug-2005, 12:21
loverobot's Avatar
Cool!
May just have to replace the chain and sproks then! Anyone know of a decent place to buy?
Also bobbing some diablos on as well... just quoted £150 fitted and balanced which seems good at leeds bike tyres (off the bike)
Old 30-Aug-2005, 12:26
B&C Express next day for your sprockets/chain etc
Old 30-Aug-2005, 12:31
loverobot's Avatar
Thanks a lot - will look into it
TBH i have been thinking of swapping the 600ss for a 748 but considering i would have to lob 3k into the pot and mine is really nice i am changing my mind - a long ride through masham and leyburn yesterday helped this thought process
I am not especially highly skilled and only just am trying to get my knee down - am currently on sportmax though which i dont think helps - also the seating position seems a long way from the ground! (much longer than my fzr600 trackbike!)
Old 30-Aug-2005, 13:08
AK's Avatar
DSC Member AK AK is offline
2 years - or 12,000 miles, whichever comes first. But as has been said - if they are left in all 'weathers' - like sun, then its prudent to do them sooner
Try some Pirelli Diablo's - will really help the handling
Old 30-Aug-2005, 13:11
loverobot's Avatar
Thanks again - booked in for the diablos so cant wait
Next stop suspension set up - what is everyone using for the 600ss? I weigh 11st 'all up' - not sure what is classed as standard?
sorry to ask loads of questions
Old 30-Aug-2005, 17:29
The front id not adjustable,so you if you are not happy with it,you will need to experiment with differant fork springs and oil.I think Hyperpro do,or did, kits for these bikes.
The rear is adjustable for preload and rebound only.Its just a matter of setting the sag then altering the damping to suit you.A shock off a similar age 900SS would give you more adjustment.
Std settings should be in your handbook.
Old 30-Aug-2005, 17:31
loverobot's Avatar
Thanks for the above - I dont have a handbook - hence the question - and i cant find it in the haynes manual either - the rear shock has a dial and adjustment with c spanners as well it looks like....
Old 30-Aug-2005, 17:49
Yep,the collars you adjust with C spanners are the preload.(Use these to set the sag)
The dial,(is it a dial,or screw?) is for the rebound.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:28.
