Old 30-Aug-2005, 17:09
dst1's Avatar
dst1 dst1 is offline
Mood: thrash the bitch
50mm Termi`s
I have just purchase a set of 50mm Termignoni pipes for my 916.
The pipes came off a 996 and come complete with size convertor pipe, straps, springs and the E-prom.
What do I need to do to put these on my 916 and what difference can I expect.
Old 30-Aug-2005, 17:16
ziggi's Avatar
ziggi ziggi is offline
You'll need some spanners and allen keys and a chip puller & a little bit of time to line them up straight. I would recommend making sure you have the right chip for 916 with 50mm cans.
Power gain - absolutely nothing in my experience. Sound and look good though.
Old 30-Aug-2005, 18:30
dst1's Avatar
so other than just bolting them on, do I need to get a 916 e-prom to make them work.
Old 30-Aug-2005, 19:03
Totto Totto is offline
Yes an e-prom suited to 50mm pipes for best results
Old 30-Aug-2005, 23:41
rcgbob44's Avatar
Sounds better than the last night at the proms!
Old 31-Aug-2005, 00:01
craig996 craig996 is offline
If you fit the 50mm termis do you have to chip it ? meaning if you didnt fit a chip would it run ok ?????
Old 31-Aug-2005, 08:29
ziggi's Avatar
you can certainly put them on and give a few runs to see what It's like but any more than that might not be good for the engine
Old 31-Aug-2005, 12:38
748IOM 748IOM is offline
Mood: Yellow!!
Wouldn't have thought it would do the engine any problems, its only affecting the fuel/air mixture surely?
Worst case it'll run a bit rough until the mixtures sorted by the replacement chip.
Old 31-Aug-2005, 13:02
rxtim rxtim is offline
The air/fuel mixture is somewhat critical though, you don't want it too lean and going bang.
Old 31-Aug-2005, 13:28
E-proms are not expensive , not really worth the risk
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:13.
