Old 01-Sep-2005, 19:54   #1
andya andya is offline
andya's Avatar
Scary fuelling glitch?
Hi
My 888 Strada has a bit of a potentially scary fuelling glitch.
When riding along normally its as if you've hit the kill switch for a split second then it cuts back in again.
Its only done it a few times ranging from a split second (like a misfire) to about a second or so.
luckily its only done it while upright so far.
Any ideas
Andy
Old 01-Sep-2005, 20:08   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Are you sure it's not electrical?
My monster was doing that... turned out to be the sidestand switch not making proper contact.
Happened to me going through Mansfield with my knee on the deck!
Old 01-Sep-2005, 20:50   #3
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Had a similar problem on my 851
Went through all sorts and it turned out to be the alarm
Removed alarm - problem solved
Best of luck!
Old 01-Sep-2005, 21:08   #4
The next time this happens, check your tach needle. If it drops to zero, then you’ll know that there’s no signal output from the engine management computer. This means that it also won’t be sending timing information to the coils or the fuel injectors.
If this is the case, the problem could be in the sensor inputs to the computer, the computer itself, or just in the associated wiring/connectors. If the tach needle doesn’t drop, the problem is more likely in the injector relays.
Have your dealer use their Mathesis ECU tester to check the computer and sensor outputs for any obvious problems. The crank position sensor and TPS are likely candidates.
Because of similar problem reports, I’d first suspect that the crank position sensor needs repositioning to get the correct gap, or possibly need replacement.
Old 01-Sep-2005, 21:14   #5
I take it that was Mansfield the corner, not Mansfield, Notts
Old 01-Sep-2005, 22:25   #6
NBs996's Avatar
Jools, you are correct. I wouldn't dare to ride anywhere near mansfield town!
Shazaam, that's just was I meant to say
What I've heard (but fortunately not experienced) about crank position sensors, the bike ought to be running as rough as a badgers ar$e if it's faulty.
I'm voting for something as simple as a bad connection somewhere.
Old 01-Sep-2005, 22:28   #7
If your tacho is bouncing around check the earth connection from the battery, had my terminals vibrate loose and had similar symptoms
Old 01-Sep-2005, 22:52   #8
andya's Avatar
Hi
Thanks for all the suggestions - slightly confused though - my bike has a mechanical tacho?
Old 01-Sep-2005, 22:55   #9
Redsps Redsps is offline
Redsps's Avatar
had the same problem on my 851 , as some other member will know.
random cutting out at any speed etc, flip the kill switch off, then on again quickly, back to normal.Can be a bit hairy on a motorway in the fast lane when it happens .
I tried every thing without success, when it went into baines, it turned out to be a dry solder joint in the managment module under the seat. problem solved, but it took a while to find it.
Old 01-Sep-2005, 23:41   #10
andya's Avatar
Sounds like it could be a connection fault somewhere and in fact once it happened over a particularly bad repair in the road which jolted the bike.
Think I've got something to do now this weekend!!
Cheers Guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:19.
