  #21
Old 07-Sep-2005, 12:25
748IOM 748IOM is offline
Mood: Yellow!!
Desmoquattro?
  #22
Old 07-Sep-2005, 12:35
Sounds good to me!
  #23
Old 07-Sep-2005, 12:47
BDG's Avatar
BDG BDG is offline
A WORD FROM THE UNWISE
I'm certainly not a mechanical expert, engineer, Shazaam, or whatever, could be best descibed as an 'armchair expert' having read a lot on the net.
What i can talk about is the four, 4 valve engined bikes that i've covered quite a few miles on and related rocker experiences.
ST4 only did 6500 miles, so too early for any problems. Rockers not checked at 6000 service though.
ST4s just under 20,000 miles from new, no rocker problems (and yes they were checked). Maybe i was lucky or the rocker problem improved by 2001.
Year 2000 SPS bought secondhand with 7000 miles on the clock. Soon after getting this bike it needed 2 rockers and Nelly at Cornerspeed also reckoned that 2 others had already been replaced already. This bike was sold to my good mate earlier this year and i still ride it at times now. It has now done over 17,000 miles, just had full service by Nelly and clean bill of health on the rockers. I have heard that the cams on the SPS give the rockers a harder time as well.
Year 2001 996R with the first 'stretta engine, again bought early this year secondhand with 7000 miles from the brother of a lad at work so i knew its history. This is now just passed 14,500 miles and (touch wood, fingers crossed etc) no rocker problems, though i have read that the 'stretta engines do not suffer from rocker problems.
My armchair expert research (the Sigma Performance site has a particularly good article www.sigmaperformance.com )
concludes that 3 factors other than luck affect rocker wear.
Firstly the older long stroke 4 valve engines can take upto 90 seconds to start getting oil to the rockers on start up, therefore carefull start up/warm up before riding away is important along with not thrashing a cold engine before it is warm (although this last point would apply to any engine, being in the courier trade i have experienced a few high mileage bikes and vans) thereby allowing 90 seconds to get oil to the rockers. Annoys the neighbours but cheaper than new rockers.
2.
Although Ducati rec 10/40 oil, various peolple suggest 15/50 is better as being thicker the oil film clings to the rockers for longer, therfore protecting them for the next start up. I'm also from the school of thought that engines used frequently are better than those started once in a blue moon.
3.
Ducati themselves say that it is absolutely crucial that valve clearances are set correctly and this affects rocker wear. If you use a mechanic who may not do the job to perfection, and it is not an easy job you may suffer the consequences.
My experience would suggest that the 'stretta engines have cured the problem, and that in the case of the SPS with its evil cams (4 rockers in its early life) then 10,000 miles of carefull warm up, using 15/50 oil, regular use and first class servicing by Nelly at Cornerspeed has resulted in no rocker problems.
I must add in Nelly's defence i'm sure he doesn't guarrantee no rocker problems, and i'm sure other experts do the job properly (but some may not), i can only speak as i find. Finally i have also heard that Ducati have produced numerous updated rockers to try and cure the problem, and it may be that the newer rockers have done so, but there are still a lot of the original rockers, as well as the original cams in the SPS.
To sum up, warm up carefully for 90 seconds, use a quality 15/50 oil (changed every 3000 miles rather than 6000 miles), and correct valve clearances, minimises the risk of rocker problems in my opinion.
  #24
Old 07-Sep-2005, 14:00
Wot Shaun said.
  #25
Old 07-Sep-2005, 15:53
steve748kent steve748kent is offline
I had all mine replaced recently with Ducati UK footing part of the bill,but it still cost me over £900 for a service aswell. And guess what, it went back into the dealers this morning because it's started to play up again,hopefully this time it's nothing major,but it seems to have the same symptums.
  #26
Old 07-Sep-2005, 16:14
Wylie1's Avatar
Wylie1 Wylie1 is offline
Originally posted by TP
Not strictly true Paul. The testastretta engines aren't supposed to suffer from rocker issues.
Phew.....I was getting worried reading this post
  #27
Old 07-Sep-2005, 16:55
BDG's Avatar
BDG BDG is offline
...All the four valves bikes have the problem....
Not strictly true Paul. The testastretta engines aren't supposed to suffer from rocker issues apart from the 998R's.
  #28
Old 07-Sep-2005, 16:57
Shaun, not like you to forget the 749/999 in that scathing statement
  #29
Old 07-Sep-2005, 16:58
Don't you mean the first generation teste engine? Wouldn't happen to the new generation
  #30
Old 07-Sep-2005, 18:07
Getting confused now! I thought that the testastretta engines, even the early ones had extra oil feed pipes going up to the head.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:18.
